New to the Hobby. Looking for advice.
DavidZak
Bunnlevel NC
Hi all, I'm new to the hobby and need a little help setting up my Home base CB station. I just purchased a JC Penney model: 2621 40 channel CB and a 13.8V power supply that I will be using a my base. The cb came with a Through glass window antenna. Any info on JC Penney model: 2621 would be greatly appreciated. I will be using standard tv cable with adapters to connect the antenna. Now the big question is: I have a TV antenna mounted to the roof that's not in use. Can I mount a cb antenna above the tv antenna using clamps? If so, what would be a good inexpensive antenna to use. Your input is appreciated.
w2rea
Western NY
The TV coax cable won't work. The cable needs to be 50 ohm coax. It looks like the TV antenna mast will work. It looks like the TV antenna will need to be moved down lower on the mast a foot or so. You will need a base station antenna. It sounds like the through the glass antenna you mentioned is for mobile applications. I would suggest the imax 2000 it's a inexpensive decent antenna.
CT
I predict the power supply will cause a HUGE hum in your signal incoming and outgoing, due to poor filtering on the power supply.
Also, yes - you need the proper Coax or the impedence will be mis-matched.
KK4JUG
GA
Throw the window antenna away. It'll work great if you want to talk with someone down on the corner but it's not good much else.
Not finding any specifics on that radio, but that's OK, give it a try.
As for the power supply, can you provide some details on that?
Yeah, toss that. They don't work well at all. You'll be lucky to get a couple of blocks with one of those.
Despite what people will tell you, the 75Ω coaxial cable will work. There will be a bit of additional loss due to the impedance mismatch, but it's not going to damage your radio. It's not an ideal cable, and if your budget allows, it really is worth getting something more appropriate. If your budget is tight, it'll work. Many amateurs use old cable TV cable to connect larger antennas.
If your budget will allow, get some of the higher tier RG-8 cable, or better yet, Times-Microwave LMR-400.
Depends.
I don't see any guy wires in the photo, so adding more weight/wind load to the top of that could be a problem.
As for "good" antennas, depends on your budget. You can use a mobile CB antenna as a base, but you'll need to make sure you duplicate the ground plane under the antenna that the vehicle would have provided.
DavidZak
Bunnlevel NC
Depends.
What about a 102" whip antenna?
DavidZak
Bunnlevel NC
Depends.
Pyramid PS9KX Universal Compact Bench Power Supply-5 Amp Linear
That would work fine, however….
Usually the 102" whips are designed to use the spring at the base. The total length should be about 108" to be resonate on CB frequencies.
Also, you still need the ground plane under the antenna. The 102/108" whips are quarter wavelength long and are designed to be mounted on a vehicle using the vehicle body as the ground plane.
But you can fabricate your own out of conduit, copper pipe, wire, etc. Do a web search on building your own 1/4 wave antenna. There's a lot of websites that will show you how to do it, along with the calculators to figure out the dimensions.
Thanks for the advice. I appreciate it very much. I didn't think anyone would reply.
A LOT of us got our start in CB. Don't let any ham, hobbyist or even professional tell you otherwise. CB is a great place to start. I used my dad's old CB radio back in the early 1980's with a 1/4 wave whip mounted off the fence. Was able to talk to a high school friend a few blocks away. Between CB and scanners, that let to me getting my amateur radio license. A while later I was working in the telecom industry. Now I get paid to do this stuff full time. And it all started with an old CB my dad bought at JC Penney's. I think it was a Kraco 23 channel.
DavidZak
Bunnlevel NC
I think the JCPenney CB models usually started with a "62". If yours has the scan feature, it might be the 6221 model.
Yes. 6221 is the Model #. I can't find any info on it. I believe it was made by Hitachi but I could be wrong. I should receive it in the mail today. It does have the scan feature.
DavidZak
Bunnlevel NC
I have a buddy of mine who lives about 10 miles away from me. We are looking communicate thru CB radio. The land is fairly flat country area. Is 10 miles being realistic with decent antennas mounted fairly high on the roofs?
DavidZak
Bunnlevel NC
Jc Penney Model 6221 is the correct model.
mrweather
Yes, all else being equal that's realistic. Back in the day I had a stock (4 watt) Radio Shack CB feeding a roof-mounted 1/4 wave groundplane antenna (about 15' AGL) and could reliably work other base stations within 10 miles.
DavidZak
Bunnlevel NC
Great, That's exactly what I'm looking to do. I have my CB. Now I'm looking to purchase my antenna. A friend of mine gave me a dual band Diamond Antenna NR770HAB 140/440 Hz antenna. Can I discard the rod and use the connector/bracket and cable purchasing a longer rod that works CB frequency? See pic.
