New to this.
jman_08
Im new to the Whole amateur Radio Business i however do a lot of storm chasing and have heard you can talk to storm chasers with a ham radio. I want to keep it as simple as possible and am wondering what i would need to hookup a good Ham Radio In my vehicle?
Also without going to crazy would i be able to just hook this radio to the cigarette lighter for power and i just want a simple magnetic antenna that i can transmit and receive on. That would hook to this ham radio.
D00D
You could probably get away with a simple 2M rig and the Technician license. A single band radio won't set you back much. I'd steer clear of running it from your cigarette lighter. The average current draw of a 2M rig is about 8.5A. I'm pretty sure that's beyond or near the limit of your lighter plug. As for the antenna I'm a huge fan of the Comet SBB-5. I just have to question the logic behind a mag mount when you plan on chasing severe weather.
AK9R
Staff member
Super Moderator
Central Indiana
There's nothing wrong with using the cigaratte lighter socket to power a radio as long as you understand the limitations.
First is current capacity. Lighter circuits in most modern cars are good for 10-15 amps. Typically, 50-watt 2m ham rigs draw around 10-15 amps on high power. However, most of these radios have selectable power outputs. Drop the power down to 10 watts and the current draw is much less--well within the capabilities of a lighter socket. In a metro area, you can probably hit most 2m repeaters at that power level. You just have to keep in mind that out in a rural area, you may need to run high power, but the lighter socket may not take it.
The real problem with this set up is resistance, voltage drop, and heat. Lighter plugs usually don't make very good contact in lighter sockets, so the connection has a high resistance. A low currents, that resistance isn't much of a problem. At higher currents, that resistance translates into a significant voltage drop which means that if you try to run the radio at high power (high current draw), the voltage drop may be so high that the radio does strange things because of the reduced voltage. Also, a high currents, that resistance translates into heat build-up in the lighter plug which will melt the plug.
The second problem is noise from other devices in the vehicle. Because the lighter wiring often goes through various fuse and distribution panels under the dashboard or under the hood, the lighter wiring often picks up electrical noise from the alternator, ignition system, fuel pump, or various on-board computers. My experience is that most problems with electrical noise can be traced to poor power wiring going to the radio. Running heavy gauge wires directly to the battery often cures the noise.
Can you get by powering a radio from a lighter socket? Yes. Is it the best way of doing it? No.
jman_08
That Antenna you showed me for the radio do i need any special type of cable to hook that into the back of the radio or does it come ready to connect to the radio?
I Have stormed chased with an older style radio and a magnetic antenna for a long time and found its the easiest route.
D00D
If you're talking about the Comet it comes with either a UHF or NMO mount for the antenna side. I use NMO so I picked up a NMO mount cable and it came with a PL-259 for the radio end. Regardless of which antenna you end up with 99% of your radios will take a PL-259 connector.
