New to trunking scanners
RWS23499
Sapulpa Oklahoma
I live in Sapulpa Ok., (Creek County) and would like to listen to county law enforcement and any other channels I can. Not necesarily Highway Patrol. Will I have to buy a digital scanner or can I buy one of the cheaper trunking scanners. Really didn't want to spend $500 on a scanner. I have a couple of old scanners, Uniden BC 855 XLT. They won't pick up a whole lot except the towns around here that are still on the old 155.700 channel. All help appreciated. Rick
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Hi RWS23499 welcome to RadioReference :)
An analog trunktracker will do fine on the Oklahoma DSP trunk system.
Your talkgroups are listed as analog mode.
33296 A Sapulpa Police A Dispatch
33328 A Sapulpa Police B Secondary
33360 A Sapulpa Fire A -- Dispatch
33392 A Sapula Fire B
go to the WIKI and click on Analog trunktrackers to see which model you would prefer.
RWS23499
Sapulpa Oklahoma
New User
Thank you MCIUPA for your fast reply. Went to RS yesterday and purchase a Pro 163 scanner. Had them program it for me. I don't think they got it right. I plugged it in this morning and have heard nothing. They used Scancat-Lite-Plus software to program this scanner.
The RS manual is a little confusing.
May need an outside antenna, since I live outside of Sapulpa.
Do I need to use a different software and try to program this myself?
All help greatly appreciated.
N8IAA
Fortunately, GA
Thank you MCIUPA for your fast reply. Went to RS yesterday and purchase a Pro 163 scanner. Had them program it for me. I don't think they got it right. I plugged it in this morning and have heard nothing. They used Scancat-Lite-Plus software to program this scanner. <It is known as scancr**p:)>
The RS manual is a little confusing. <Without a doubt. If I hadn't had previous experience with a Pro-97, I'd a been lost.>
May need an outside antenna, since I live outside of Sapulpa. <If you live between Kellyville and Sapulpa, put in the Kellyville tower CC's.
Do I need to use a different software and try to program this myself? <Without a doubt! Get the USB programming cable at RS. Then go download Win97 at: Software for RadioShack PRO-series (PRO-92, 93, 95, 96, 97, 99, 163, 164, 106, 197) and GRE PSR-series (PSR-500, 600, 300, 400) scanners DonS lurks here on RR and will gladly help you if you have problems. Plus it has a thirty day free trial. A premium subscription to RR also allows you to download what you want to put in the scanner via the software.>
HTH,
Larry
RWS23499
Sapulpa Oklahoma
Kellyville Tower CC
Thank you for your reply. How do I put in the tower CC? I am a novice at this new stuff, the old systems were easy to program. New stuff is tough on an old guy, Ha Ha. Rick
