New to XTS5000 - Confirm Tx Dev is 2.5kHz and 12.5 kHz channel spacing?
K6PYR
Member/Feeder
Hi all,
I'm new to programming an XTS5000. As you know, the channel assignments allows for selection of Tx Opt Dev and TX Opt Channel Spacing.
Would somebody confirm that for normal analog, VHF, fire department type operations these should be set to 2.5kHz and 12.5 kHz respectively?
Thanks!
K6PYR
Member/Feeder
Further thought on this: Is there a way to set that as the default? Right now the default is 5.0/25.0. which means I have to change it for every single entry. I have not found a menu option that sets this as a default. I've looked in the Radio Config and the personalitiy menus.
rescue161
KE4FHH
Hubert, NC
You can also right-click on the correct setting and select "Fill Value Up/Down" and it will adjust all of the channels in that column. Very handy for large zones.
GTR8000
NY/NJ Database Guy
BEE00
Ah yeah, forgot about Fill Up/Down. Just make sure that the channels are not RX Only, otherwise you won't be able to change the TX Deviation.
