TwoToneDetect New TwoToneDetect in the works - Python based
tecker
Deshler, NE
I'm trying to install the latest version of TTD (v63) on Ubuntu 12.04 but when I open the TwoToneDetect63Pi.pyc file it says "There is no application installed for Python bytecode files." When searching for a program to open it, nothing appears in the list. I have thought about trying to run TTD in Wine, but would rather not. So, what steps do I need to take?
It sounds like you need to go into the command line and execute it from there using the "python TwoToneDetect63Pi.pyc" command in the TTD folder. Take a look at this post compiling - How to run a .pyc (compiled python) file? - Ask Ubuntu . Essentially you cannot run the .pyc file from the gui. You might be able to create a shell script that could be launched pretty easily. Be ready to install some dependencies for python and make sure you don't copy your config file from the old one over since things will probably be different. Good luck on that. Sounds interesting if you can get it to go.
BTW, what type of computer is it? If you look on the outside of the case can you find a Windows Certificate of Authenticity? If you can then you just need to find recovery disks for that type of computer and restore it. If it was a homebuilt machine it likely wont have one. It could be easier to just look around for a copy of Windows XP on ebay or the like. Probably not worth it but you could go down that route if you wanted.
tecker
Deshler, NE
i would love to set this up but i am unsure on how to do it. can anyone help me?
thanks,
matt
The help page Andy linked it pretty complete. If your email has 2-factor authentication (a system where they will either text you a number or you use an app on a smart phone to generate a code) then applications that that don't do text or app code entry use these special passwords. Follow that link and it should tell you where to click. If you dont have 2-factor turned on then you need to just log in via a browser and "check your email" from that computer.
Have you considered making a specific gmail just for paging things out?
DC31
Massachusetts
First of all, thanks for making such an amazing program. It has been a huge asset for many of the EMA organizations in our county.
We have had TTD running smoothly on a Windows XP machine for a long time now, but the computer finally died. We have had another computer donated to our Rescue Squad with no operating system. Rather than spending our resources on purchasing a copy of Windows, I have been trying to get TTD running on Ubuntu, but with little success. Can you release a detailed tutorial on setting it up for Ubuntu?
If I can get the program installed and running, I am confident in the setup, it's Linux/Ubuntu I am unfamiliar with.
Thanks for any advice or assistance, and sorry for the verbose post.
Try running it from the linux command line:
$ python TwoToneDetect63Pi.pyc
See if that gives you different results.
Jim
gmbaker13
Georgia, Vermont
i would love to set this up but i am un shure on how tp do it. can anyone help me?
thanks,
matt
The problem you are having is the same problem that I had with my Gmail Account. The fix is simple to fix go to this site and it will tell you what you need to do do. https://support.google.com/a/answer/105694?hl=en
Good luck
PS: besure to to enable the IMAP it gives you unlimited use also besure to set the File folders to unlimited as well..
gmbaker13
Georgia, Vermont
Good luck
In the Gmail settings go to Forwarding and POP/IMAP Item 1. Status: POP is enabled for all mail that has arrived. Item 2. "Keep Gmail's copy in the Inbox" . Item 3. Status: IMAP is enabled ( in most set ups you will find this to be disabled ) But for the TTD to work you need it to be enabled to give you unlimited messaging. You also need to set the following:
Auto-Expunge on - Immediately update the server. (default).
Folder Size Limits: Do not limit the number of messages in an IMAP folder (default).
krokus
Southeastern Michigan
Wirelessly posted (Opera/9.80 (Android 2.3.4; Linux; Opera Mobi/ADR-1309251116) Presto/2.11.355 Version/12.10)
Why not install XP, using the license from the deceased computer?
gmbaker13
Georgia, Vermont
Go to your Gmail Settings: FORWARDING AND POP / IMAP
Item 1. Status: POP is enabled.
Item 2. "Keep Gmail's copy in the inbox"
Auto-Expunge on
Then SAVE CHANGES
gmbaker13
Georgia, Vermont
thanks,
matt
Yes I can help you, go to Gmail settings in the setting go to FORWARDING POP / IMAP
Item 2. " Keep Gmail's copy in the inbox "
Item 3. Status: IMAP is enabled the will give you unlimited messages
Auto-Expunge on
Folder Size Limits:
Then SAVE CHANGES
This will correct your problems that you are having, I know it will work it happen to me.
zeecee265
Hey all, thanks for the great suggestions on the command line. I will give that a try for sure.
Its just an old Dell computer, and it does have a CoA sticker on the side. The problem I ran into was I don't have any of the disks for it. The only OEM windows disk I could find to download online was for XP SP3, and the key isn't working on that. That's a great suggestion about trying to find an older disk on eBay, but this Linux thing has challenged me and now I must conquer it. (with y'all's help)
DC31
Massachusetts
Hmmmm.... Is that raspberry pi that i smell in your future?
R_Rabbit10
Thanks for this great program!
Just wondering if there is a way to have TTD automatically select the proper input (and output) channel on startup (line in)? I now have to manually select the correct input each time after a powerfailure (UPS only works so long to keep machine running....) or reboot.
mattnelson26
Hopkins, Minnesota
my friend is still having trouble with it so this is the log and problem.
Traceback (most recent call last):
File "<string>", line 458, in mail
File "C:\Users\Deer Creek Fire Dept\Google Drive\Python\build\pyi.win32\TwoToneDetect63_debug\outPYZ1.pyz/smtplib", line 604, in login
SMTPAuthenticationError: (534, '5.7.9 Please log in with your web browser and then try again. Learn more at\n5.7.9 https://support.google.com/mail/bin/answer.py?answer=78754 rx4sm29490790pab.13 - gsmtp')
Email not sent on attempt 1trying again in five seconds for North Branch Fire-Rescue page received at 17:19:03 on 11/18/13
537.0 5168
537.0 5163
537.0 5114
537.0 5115
537.0 5118
537.0 5125
537.0 5150
537.0 5148
537.0 5152
537.0 5109
537.0 5153
537.0 5117
537.0 5139
537.0 5133
537.0 5153
537.0 5122
537.0 5164
537.0 5121
537.0 5090
537.0 5097
537.0 5137
537.0 5122
537.0 5131
537.0 5129
537.0 5102
537.0 5090
537.0 5074
537.0 5104
537.0 5132
537.0 5097
537.0 5060
537.0 5092
SMTPAuthenticationError: (534, '5.7.9 Please log in with your web browser and then try again. Learn more at\n5.7.9 https://support.google.com/mail/bin/answer.py?answer=78754 yh1sm25945338pbc.21 - gsmtp')
Email not sent on attempt 2trying again in five seconds for North Branch Fire-Rescue page received at 17:19:03 on 11/18/13
537.0 5103
537.0 5129
537.0 5103
537.0 5109
537.0 5097
537.0 5087
537.0 5107
537.0 5130
537.0 5118
537.0 5178
537.0 5174
537.0 5188
537.0 5154
537.0 5166
537.0 5155
537.0 5167
537.0 5176
537.0 5208
537.0 5160
537.0 5155
537.0 5153
537.0 5132
537.0 5185
537.0 5171
537.0 5179
537.0 5167
537.0 5163
537.0 5068
537.0 5085
537.0 5107
537.0 5103
SMTPAuthenticationError: (534, '5.7.9 Please log in with your web browser and then try again. Learn more at\n5.7.9 https://support.google.com/mail/bin/answer.py?answer=78754 xn12sm29490111pac.12 - gsmtp')
Email not sent on attempt 3trying again in five seconds for North Branch Fire-Rescue page received at 17:19:03 on 11/18/13
537.0 5111
301.0 10499
537.0 5176
537.0 5102
537.0 5135
537.0 5135
537.0 5139
537.0 5160
537.0 5080
537.0 5219
537.0 5267
537.0 5139
505.0 9357
591.0 8523
532.0 9452
537.0 9288
527.0 8912
537.0 6277
656.0 10070
537.0 10884
419.0 8315
414.0 9328
414.0 9662
403.0 8709
414.0 11329
403.0 8601
414.0 10401
537.0 5550
max retries exceeded, failed to send email
he also did what gmbaker13 told us to do with gmail settings.
thanks,
matt
gmbaker13
Georgia, Vermont
TTD Email not sent
537.0 5168
537.0 5163
537.0 5114
537.0 5115
537.0 5118
537.0 5125
537.0 5150
537.0 5148
537.0 5152
537.0 5109
537.0 5153
537.0 5117
537.0 5139
537.0 5133
537.0 5153
537.0 5122
537.0 5164
537.0 5121
537.0 5090
537.0 5097
537.0 5137
537.0 5122
537.0 5131
537.0 5129
537.0 5102
537.0 5090
537.0 5074
537.0 5104
537.0 5132
537.0 5097
537.0 5060
537.0 5092
537.0 5103
537.0 5129
537.0 5103
537.0 5109
537.0 5097
537.0 5087
537.0 5107
537.0 5130
537.0 5118
537.0 5178
537.0 5174
537.0 5188
537.0 5154
537.0 5166
537.0 5155
537.0 5167
537.0 5176
537.0 5208
537.0 5160
537.0 5155
537.0 5153
537.0 5132
537.0 5185
537.0 5171
537.0 5179
537.0 5167
537.0 5163
537.0 5068
537.0 5085
537.0 5107
537.0 5103
537.0 5111
301.0 10499
537.0 5176
537.0 5102
537.0 5135
537.0 5135
537.0 5139
537.0 5160
537.0 5080
537.0 5219
537.0 5267
537.0 5139
505.0 9357
591.0 8523
532.0 9452
537.0 9288
527.0 8912
537.0 6277
656.0 10070
537.0 10884
419.0 8315
414.0 9328
414.0 9662
403.0 8709
414.0 11329
403.0 8601
414.0 10401
537.0 5550
thanks,
matt
I Think what could be the problem is he may have a email address that is not correct if he has one or more addresses wrong it will lock up the sysytem and it will not send the email messages the same goes for if he was to use phone numbers if he was to enter a wrong phone number it will lock up the system and none of the out numbers in the list would get the message because of that one number was wrong or email was wrong, so he needs to be sure that all emails are good ones before using them.
Also Verify IMAP is Enabled and set to Unlimit File Size.
Gary
tecker
Deshler, NE
R_Rabbit, sorry for the delay. No you do not need to select each time. There is a config file that will save which input / output was selected. This config only saves the index so if audio devices are added and removed constantly then you may have an issue. This would only happen with USB sound devices though that might not be connected on boot. Give it a try and I bet you will be fine.
jhall1520
Crocker Missouri
I have downloaded and have been succesfully using the program for a week or so, we traded the Portable radio to a scanner, and now the messages come in as "The remaining parts were removed as it exceeded the limit size of MMS? Anyone ever have this problem? what can i do to fix it?
DC31
Massachusetts
Can you post the contents of the log.txt file from the TTD directory?
DC31
Massachusetts
When you downloaded the program, you extracted the zipped files to a directory. In that directory, you will find log.txt. Do a search for TwoToneDetect and it should get you to the directory.
R_Rabbit10
Thanks! Works great!
