TwoToneDetect New TwoToneDetect in the works - Python based
pete7919
I did some logging today and saw something like this happen once out of about 60 pages. I'll try to do some debugging on it to figure out what's going on but it may take awhile since it happens so infrequently.
Andy
I'm not having luck with v59. It's not recording correctly. Not skipping message this time, but the recording didn't start until the next alert. What it emailed me was the first alert label with a recording of the second alert. I emailed the log.
On the bright side, V58 has been running flawlessly.
ffryan76
South central, In
I was interested in tagging the emails or text message addresses with names. Is that possible? Could I use something like this without confusing the program: [Joe Smith]5021234567@vzwpix.com ? Would the editor be able to do this or would I have to open the tones config file and manually enter it?
Love the program Andy and your Fire Call Mapping info. I am trying to wrap my brain around that one and get it set up for my fire department.
putterizer
WI
See this, I think this will help you: http://forums.radioreference.com/st...detect-works-python-based-60.html#post1899244
It appears as though this should work with both editor and the manual config file in the testing that I just performed.
ffryan76
South central, In
aaknitt
The next version of the Tones Editor will do this automatically by having a separate field for name and email address, and then store it in the correct format. It works, I just need to get around to packaging it up and releasing it.
Andy
mattnelson26
Hopkins, Minnesota
having problems can anyone help here is the de-bug said
Succesfully retrieved local tone info
Tone1
Tone2
defaultdict(<type 'list'>, {'CENTER CITY FIRE-RESCUE': array([ 1185.2, 1185.2,
1250. , 1250. , 1250. , 1250. , 1250. ,
1250. , 1250. , 1250. , 1250. , 1250. , 1250. , 1250. ,
1250. , 1250. , 1250. ]), 'LINDSTROM FIRE-RESCUE': array([ 1217.8, 12
17.8, 1321.2, 1321.2, 1321.2, 1321.2, 1321.2,
1321.2, 1321.2, 1321.2, 1321.2, 1321.2, 1321.2, 1321.2,
1321.2, 1321.2, 1321.2])})
defaultdict(<type 'list'>, {'CENTER CITY FIRE-RESCUE': 1, 'LINDSTROM FIRE-RESCUE
': 0})
1177.0
1177.0
1177.0
1177.0
1177.0
1172.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
CENTER CITY FIRE-RESCUE Tone Set Found
Tone1
Tone21242.0
delay timer CENTER CITY FIRE-RESCUE 18:39:04
1242.0
'c:/test.bat' is not recognized as an internal or external command,
operable program or batch file.
446.0
274.0waiting for audio CENTER CITY FIRE-RESCUE 18:39:05
recording audio CENTER CITY FIRE-RESCUE 18:39:05
532.0
462.0
322.0
381.0
500.0
1193.0
898.0
478.0
408.0
559.0
440.0
457.0
489.0
317.0
done writing WAV CENTER CITY FIRE-RESCUE 18:39:24
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 01FB9640] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01FB9640] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/CENTER_CITY_FIRE-RESCUE_2013-03-2718_39_24_171000.w
av':
Duration: 00:00:18.57, bitrate: 176 kb/s
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 1 channels,
s16, 176 kb/s
Output #0, amr, to './audio/CENTER_CITY_FIRE-RESCUE_2013-03-2718_39_24_171000.am
r':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Audio: amr_nb, 8000 Hz, 1 channels, s16, 10 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libopencore_amrnb)
Press [q] to stop, [?] for help
size= 25kB time=00:00:18.58 bitrate= 10.8kbits/s
video:0kB audio:24kB global headers:0kB muxing overhead 0.023921%
done converting to AMR CENTER CITY FIRE-RESCUE 18:39:36
Traceback (most recent call last):
File "<string>", line 447, in mail
File "C:\Users\Deer Creek Fire Dept\Documents\Python\build\pyi.win32\TwoToneDe
tect59a_debug\outPYZ1.pyz/smtplib", line 604, in login
SMTPAuthenticationError: (535, '5.7.1 Username and Password not accepted. Learn
more at\n5.7.1 My client isn't accepting my username and password - Gmail Help wn10sm8
394401igb.2 - gsmtp')
'c:/test2.bat' is not recognized as an internal or external command,
aaknitt
Tone1
Tone2
': 0})
1177.0
1177.0
1177.0
1177.0
1177.0
1172.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
1242.0
Tone1
Tone21242.0
1242.0
446.0
532.0
462.0
322.0
381.0
500.0
1193.0
898.0
478.0
408.0
559.0
440.0
457.0
489.0
317.0
nvalid.
av':
s16, 176 kb/s
r':
Metadata:
Stream mapping:
Have you recently changed your gmail password without updating it in the program?
aaknitt
yes but i changed it in the program
thanks,
matt
Double check to make sure you entered it correctly. The error you're getting is telling you that the program can't log in to gmail using the username and password that you've provided.
Also, make sure you restart the program after making changes to the config info.
Andy
JBaumannINC
Hello,
I recently upgraded to the new 59 version and this is the error I'm getting. For a while it would send the text emails but no audio. Then the text emails stopped. This is what it is throwing
delay timer Hancock Fire 22:41:22
waiting for audio Hancock Fire 22:41:22 File "<string>", line 443, in mail
File "C:\Users\Deer Creek Fire Dept\Documents\Python\build\pyi.win32\TwoToneDetect59a_debug\outPYZ1.pyz/smtplib", line 242, in __init__
gaierror: [Errno 11004] getaddrinfo failed
I have it setup with a new gmail account and everything should be good to go there. Thanks.
nightmicu
Where to download Python version?
Hi everyone,
Trying to download and test out the Python version of TwoToneDetect but can only seem to find the Windows downloads - 58 and 59. I found a link to what I believe is supposed to contain the contents of the Python version on SourceForge but it's an empty tarball.
Can someone please point me in the right direction?
pete7919
nightmicu
If you're looking for source files, the program is no longer open source. Andy posted on 3/1 that v57 and up are not open source http://forums.radioreference.com/1925736-post1384.html
You can grab the older version here:
https://docs.google.com/file/d/0B5nsi3i1O2oyazNuQzA0UW5od1k/edit
If you're looking for the Raspberry Pi version instructions are here:
https://sites.google.com/site/radioetcetera/twotoneprogram/ttd-on-a-pi
There's a link to the Pi Tarball about 3/4 of the way down.
Thanks - does this mean that there is no longer a Python version apart from the Raspberry Pi one?
