It means your computer couldn't contact the dns server to get the ip address, so most likely your internet was down.
I'm having problems getting the program to send the emails out sometimes. I'm using version 60 with 2 different departments on it. Today had the first tone go out just fine, then on 2nd tone it received the tones and converted to amr but couldn't send out the email. It tried 3 times before it gave up. Then about 30 minutes later received another call and it sent out the email just fine as if nothing was wrong. The tone set for this certain dept that had the error only has 3 email addresses to send to, all phone email gateways. The error code I got for the 2nd tone that didn't send was:
gaierror: [Errno 11004] getaddrinfo failed
And also this one, but I always see this one and it still works regardless:
'c:\test2.bat' is not recognized as an internal or external command, operable program or batch file.
I'm using the Tones Editor instead of inputting info manually. So what I'm wondering is: (1) What is error code 11004? (2) How could it have happened? (3) What do I need to do to fix it so this error code doesn't appear in the future? And (4) Should I be concerned about 'c:\test2.bat' error?
Thanks,
Grady
Thanks,
Grady
Didn't find any blank lines in the email field. Also, I Didn't find the full error statement in the log that I could copy/paste (since I've closed and restarted the program since then) but I did take a picture of the screen with the full error statement of the incident. Attached is that picture of the error statement. Forgive me if it is poor quality, I had to reduce the image size significantly to get it to post here. I can email the original picture if needed.Can you post the full error statement? It should include something like "traceback" and include a code line number. That would help me narrow it down. When using the TonesEditor, do you have any "blank" lines in the email field that you can highlight? If so, try deleting those "blank" lines and see if that helps.
Andy
Grady
It looks like it is having difficulty contacting your email server. Have you checked the email settings in your config.cfg file? or edit configuration info from TTD main screen. From the edit configuration window on the main screen just put in your password, do not attempt to encode it, the program will do the encoding. If using Gmail log into your account from your web browser and see if it is waiting for you to confirm something.
Have you been able to send them before now or is this the first time? I'm running two v61 on two thin clients and sending them to two different account on AudioBoo without any problem using Gmail.
I had set up Boomail on another machine using TTD v57 or v58 several months ago, but that never worked either. I had BCC checked on that machine. I unchecked it & it still didn't work. This is an entirely new setup...new PC, new scanner, new location, new version of TTD. I figured I'd give it another shot with this new setup, but I'm having about as much luck with this one as I did the old one.
Since upgrading to version 60 about 3-4 weeks ago I haven't changed any of the email settings since initially setting up the program with just one department. Gmail password hasn't been changed recently, no messages to confirm anything when gmail browser opened. Email settings in config.cfg and main screen look correct to me in regard to user ID and Password. When I set it up I put my password in edit config info on main screen and let it do the encoding, when I open config.cfg password is already encoded by program. The only changes I made to the program PRIOR to this error was:
Thoughts?
Maybe a one time program glitch, or I have a setting wrong somewhere, or an internet hiccup like jhsands said?
Thanks,
Grady
The problem is Comcast requiring SSL for email login. I believe that the newest version (61) does allow for SSL and should fix your situation.Here I am attaching a copy of the set up of how I have my TwoToneDetect60 setup maybe someone can tell me why it will not send the messages to my Smart Phone.
Gary
[1] On Win7/8 you'll get an error that Telnet isn't installed. Run this from the command line:
pkgmgr /iu:"TelnetClient"
[2] Appears you may not be getting out to the world on SMTP. Go to command prompt, type
telnet smtp.gmail.com 587
and you should get something back like this:
220 mx.google.com ESMTP n5sm17350676igv.5 - gsmtp
[3] While not doing any browsing, emailing, etc, turn off your anti-virus.. If you're on a domain network where your network security guy is moronic, tell him this is being used for only this program and he can disable all the "extra" modules. Said moron probably also has the full anti-virus package running on SQL servers.
