try the one Tim sent you, use Tab F1 to import, Tab E to program
Imported in and exported ok, but when I went to program got the following message:try the one Tim sent you, use Tab F1 to import, Tab E to program
Save the file somewhere on your PC. Tab F, then F1 in the PPS. Import the file then you can choose tab D to choose which profile you want to open to modify or program to your pager.Hi Mike-
was away from the computer. Not hearing any talkgroups. Tim sent me a cp file for the RISCON system. Got to figure out how to import it into my radio. Then I can see what I am not doing right. I want to learn the proper way to program my radio so I might help other new owners in the future. I can still send you my original file if you would like. Do I use the export link in the software? what address would I send it to?
Marc
Thank you Tim-Save the file somewhere on your PC. Tab F, then F1 in the PPS. Import the file then you can choose tab D to choose which profile you want to open to modify or program to your pager.
Your “ahh-ha” moment is imminent.Thank you Tim-
I am going to look at how it's set up 1st and try to compare it to mine to see what I missed first. I would like to learn what steps or information that I need to change to make mine workable. Again- much appreciated for the file.
Marc
Hi Adam-Your “ahh-ha” moment is imminent.
OK- so I theoretically might have did it right so far. I will add some more talk groups that might be more active to see if I can hear a transmission.Locking on the control channel is what you want in P25.
It will then switch to whichever TG becomes active.
Congrats LOL now sit back and enjoyCan one have more than one primary control channel in a scan list?
I guess I can, I just received a transmission. My ahh-ha moment.
Wow! Just received another in the clear transmission.
It's working!!
Thanks for all the great input from all who responded! Much appreciated.
Thanks Mike-Looks like you have to convert from a UHF D to a VHF tab C2 note the model number
OK - Thanksyou cannot scan P25 trunking and P25 coventional at this time, it's one or the other
Yes you can have more than 1 frequency in the control channel list.
I have one system that has 13 frequencies in the list because any one of them could be
the control channel at any given time. Changes often, depends on the type of system, (Harris)
I also have a statewide system that has 100+ in the list that has 71 sites
and many freq's.
OK- Thank you.
Since Unications are commonly in use as fire pagers, you may want to check with local fire departments to see if anyone may be willing to assist you. The programming is more complex than your average scanner, but it's really a matter of knowing what to plug in and where. I personally don't try to understand all aspects of programming. Things have been simplified since we got the ability to import CSV files from RR, and firmware now in beta will incorporate several improvements aimed at the scanner user. So Unication does respond to customer input.There are no clinics available and have never met anyone in Southeast Florida that owns one.
I have been using scanners and radio equipment for over 50 years and the only reason I never purchased a Unication is my inability to understand how to program one. I've talked to people on the phone and watched many videos but makes no sense to me. I met a person on the internet that said they would write me a program for my area but that doesn't teach me why and how to program one myself or how to use a Unication. I would need someone to sit down with me and teach me step by step how to program a Unication and explain why a certain setting is chosen. There are no clinics available and have never met anyone in Southeast Florida that owns one. And I belong to two Amateur Radio Clubs. Never even heard anyone ever mentioning a Unication either. Love my Scanners and Ham equipment I use on a daily basis and understand them 100%. Maybe one day...………..
