madman227
Today i got a new uniden bcd396xt and i was able to set it to scan starcom21 but it don't stop an anything so was wondering if there is a setting somewhere i need to change..Thank
Welcome to RR.Today i got a new uniden bcd396xt and i was able to set it to scan starcom21 but it don't stop an anything so was wondering if there is a setting somewhere i need to change..Thank
captclint Now you said There are many sites to this system. Did you pick the one closest to you how would i go about selecting a differant site? ..ThanksWelcome to RR.
StarCom21 Statewide Illinois P25 Trunking System, Statewide, Illinois - Scanner Frequencies Are you using any software? If so, which one?
There are many sites to this system. Did you pick the one closest to you? Might want to try another one that is not the closest. . It should be P25 Std and the red and blue freq's entered under the site.
The default is IDsearch, so you should not have to enter any talkgroups to see if it works. If IDscan is flashing when on this system, you should change it back to IDsearch.
It all depends on whether you are using SQK-28 STARCOM pre-programmed, or are you manually entering frequencies for a particular site. The sites are listed here: StarCom21 Statewide Illinois P25 Trunking System You would need to create a system with a site 3 (3) 059 (3B) St. Clair County - Simulcast.captclint Now you said There are many sites to this system. Did you pick the one closest to you how would i go about selecting a differant site? ..Thanks
