SDS150: New Uniden Scanner announcement at SEMA 2025
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Performed a full database load speed test of the SDS150 vs SDS100. Both SD Cards are new Samsung PRO Endurance 32GB MicroSDXC. I created a new profile in Sentinel and loaded only the Full Database (11/02/2025) with all service types selected. Changed the display name to match the scanner the card was inserted into and powered the on. Getelman, Start your Engines!
Database Load Speed Test
RandyKuff
Lorain, Ohio
Indeed much faster than the 100...
CollinsURG
North Carolina
Thanks for that. Much faster. Traveling, I sometimes use the full database with GPS and filtering out excess systems with service types. This will be a huge improvement. I expect local systems will be nearly instantaneous.
fairweatherfixd
See you in the funny pages
Milwaukee, Wisconsin
Thanks for all this!
dmfalk
Eureka
Does the door clip fit the 100 as well? Wondering if the 150 door clip is better made?
My guess, no. It's shorter to accommodate the charging terminals on the 150, by the looks of it.
The battery itself, based on the cover, is longer and narrower, and have new terminals. I don't think you can switch a battery for the 100 into the 150, or vice versa.
dmfalk
Eureka
Total boot-up and load time, much, MUCH faster!
bravo14
Polk County FL
I know the batteries can't be switched. I just asking cause the 100 door clip was breaking. I wish that one guy was still around to buy a few more of them.
jasonhouk
Uniden AlphaMan
Marion, Ohio
I can honestly say I have never broken a battery clip on mine or any beta SDS100 and I have #21 from the first production run.
My beta SDS150 is #18 and no issues to report on the battery clip on that one or the engineering sample I received in March.
CollinsURG
North Carolina
Mine broke, as well as one tab on the cover. Turns out it was an expanding battery. Replaced the battery clip and superglued the tab back on. Got rid of the swelled battery. No longer charge the battery in the SDS100. Going well so far.
jasonhouk
Uniden AlphaMan
Marion, Ohio
I must be the only weird one left—I actually have the SDS100 external battery charger, but I always just plug in the USB cable at night and charge it right in the radio!:ROFLMAO:
palmerjrusa
Frederick
That was a weak point with the SDS100, my battery cover eventually broke even though I was aware of this issue and was being very careful. Surprisingly, some super glue worked as a fix but I bought a couple 3-D printed battery cover replacements from a vendor on ebay.
palmerjrusa
Frederick
Have an early production SDS100 (one that came with the smaller battery) and used the included coupon to get the bigger battery. I also bought the charger cradle that came with an extra battery.
Recently checked the status of the batteries and they've held up remarkably well. Still in good shape and haven't experienced any "swelling" issues.
