Cleveland's decided to go with their own system and has been installed about a year now. With the millions invested I doubt Cleveland will ever move to MARCS. Most of the Southwester suburbs are now on Cleveland's system.
Cleveland wouldn't move to MARCS-IP, but the capability is there for the system to connect to MARCS-IP for interoperability and roaming purposes. A big network connection would basically be all they need.
I wouldn't be surprised either way if that did or did not happen.
Patches (issi gateway) between GCRCN and MARCS-IP were used several times last summer.
i pulled the trigger and got the bcd536hp. love it so far. it's ok so far with the MARCS-IP decoding; better than the psr-800. also picking up cleveland a little better.
i have a lot to learn about this radio. can you insert wildcards with this thing like you can with the psr-800?
I received my BCD536HP last week and I live in Lorain County (N. Ridgeville) and has always had a issue with the Cleveland system and after putting the 536 online it works 100% Zero decode issues. I then purchased a DBC436HP this week and can tell just like other Uniden scanners the stock antenna is not very good, I put the adapter on it and put on the Radio Shack (GRE) 800 MHz, antenna on it and it makes a big improvement. I drive for a living and travel from Lake county to Lorain county and south to Medina county and as long as you keep the unit vertical while traveling it works great. I have owned every Uniden, GRE and Radio Shack (GRE) scanner made and this is the best improvement they have had.
Very odd, I'm only about a mile away from the jail and I'm only using the stock antenna with the radio. So you don't hear any transmissions breaking up with the system? I have even moved the radio all over the place with no improvement. While monitoring the system I can see the signal drop every once in a while and that is where I notice the loss of transmission. You would think I would have a solid strong signal at all times. Again I only have this issue with Canton/Stark. Even the MARCS system works really well. I'm going to take my 536HP to work Monday and see how it responds there.
Another observation, and this is just my speculation, but it seems like the towers in a simulcast system dynamically change each time someone transmits. Example, a dispatch call is sent out and causes all towers to broadcast uniformly but when a mobile responds maybe only one tower, (the closest one) picks up and transmits. I make this observation from the MARCS-IP because many times the base station will sound garbled and the mobile response is perfectly clear. It would be nice if there was someone on here that has actually worked on the system and could explain exactly how it works.
This may appear to be a dumb question, but with the above in mind, does anyone know if you just enable a site or two to maybe help with the simulcast problem? Of course that would only be from a fixed location like your home.
yes. It's called ID Search
