I did the update exactly as when I first got the scanner. My TRX-2 SCANNER IS NOW BRICKED. It keep saying "Waiting for MAIN unit" and will not turn on. Please advise. Thank you.
Happens to me all the time on a 1098, randomly. Upload, download, import, firmware update- never know when it's going to happen. I have to disconnect the power and reinsert the SD card. Real PITA popping the remote off and on (the magnet works). Just switched to different card and things are better, so far, else it's going back.OK, I disconnected power plug for 30 sec and scanner restarted with new firmware updates. Has anyone else encountered this message "Waiting for MAIN unit." TRX-2 seems be working well and receiving lots of Slot 2 traffic.
That depends on what DMR systems/channels have been identified by others in your area and submitted to the RRDB.
However, fellow RR member AggieCon (Justin) has created a tool to help get you going:
DMR Frequency Quick Import
This will allow you to search for DMR licenses in your area and make it easy to import them into your scanner via the EZ Scan PC app.
Is everything working in the DMR trunking or is it just me. Since the upgrade, I have not had the first decode in my DMR trunking scanning. Worked fine before the upgrade.
Removing the wildcard TG from the scan list did not make any difference.
Although the procedure is a little different between the two, I decided to program a scan group as close as possible to the MD-380. Both now are only scanning one site with 3 frequencies and 16 TGs with a wildcard in the WS-1080. Now with both side by side the MD-380 is catching all the traffic and the WS-1080 is silent most of the time. After double checking the programming I have determined something has changed. It seems as if the sensitivity or something has dropped on the TGs decode with the Whistler.
KF5MWE
KF5MWE
Continuing with experimental programming of DMR in the WS-1080 after the latest firmware update. I programmed all 4 sites with 3 frequencies each as Conventional channels with the Color Code as any, Time Slot ans any, and the Talkgroup Id as 0. Now with this configuration all works as expected.
This for me though would not be feasible. That's 12 frequencies that I would have to duplicate for each of 16 out of 40 or so talk groups that I am interested in. DMR trunking does not work as expected after the latest firmware update.
This is a DMR Capacity Plus system I am working with. I am wondering if it has something to do with the timeslot changes since there is no way to set timeslots in DMR trunking. Seems like the should be an additional column so we could set timeslot to any as with conventional.
KF5MWE
Make sure those 0.00000 frequency entries are locked out. That issue apparently was not fixed with this latest firmware update. That definitely sends the TRX off into space and causes it to miss a great deal of traffic.
