SDS150: New User favorits list, nothing to scan.
ke0pjj
Altoona, Ia
I am relativly new to Scanners. So I apploigise if I am overlooking the obvious.
I have created some favorite lists using Sentanal, and have saved it to the scanner. I have turned them on to scan, but scanner says Scan Mode, Nothing to scan. Yes, some of them are DMR, and the DMR license is active in the scanner.
** I can pick these up on my computer using sdr trunk. I can also pick the above up using a DMR HT.
Thanks,
John
dave3825
Suffolk County NY
Search forum for “nothing to scan”. There a ton of posts with solutions. Might even be a sticky.
fxdscon
¯\_(ツ)_/¯
You can also check the section for that message on page 62 of your owner's manual.
Nasby
Ohio
Two common things that I’ve seen cause this.
1) assign a Favorites List Quick Key to the FLs.
2) In the profile section, make sure you have both monitor and download selected.
J-Wrock
Kansas City Area
Thanks,
John
Check out this article: Nothing to Scan - The RadioReference Wiki
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Export you Favorite List to an .hpe file, then zip that file and upload it here, so someone can take a look at it, and maybe fix it.
Fairgrounds and Prairie Med have no towers/freqs so it will never scan those. Can't tell on the next two, but think you do have towers for Polk Simulcast.
If you didn't set a FL quick key you will get Nothing to Scan.
phask
zanesville
Not true - it will always be on, with no way to turn off other than through the menu.
Enforcer52
Lake Livingston, TX
Yeah your are right was thinking of something else, thanks for correcting.
dmfalk
Eureka
The usual culprit is that Service Types (in the scanner's menu) weren't enabled.
dmfalk
Eureka
Or someone does not program in sites.
Look at his original graphic, above. Since his entry of the Iowa State Fairgrounds came from the county level (USA > Iowa > Polk > County Systems), he has the entire system copied into his Favourites List. The sites are listed in the separate sublisting of "Fairgrounds". He did that correctly! So again, I reiterate that the most likely culprit is that the Service Types weren't enabled.
Enforcer52
Lake Livingston, TX
That's another reason I don't like Sentinel favorite lists, does not distinguish between Sites/Freqs and TGIDs, so hard to tell in a screen shot unless fully expanded listings.
Just My Opinion!
dmfalk
Eureka
It's a bit confusing, yes, especially with sites listed separately in Sentinel, like that, but as I said, he copied the entire system correctly. Now, on his scanner, he should hit the side menu button (the red three-line button), go to Select Service Types, and go down the list, turning every listing that says "Off" to "On", ignoring the triple dashes (they're not available in this instance), then he should be able to hear what's being broadcast.
garys
Central Texas
Here is the all in one covers just about everything "Nothing To Scan" wiki article from Radio Reference. Your reason will be in here somewhere. These are not simple scanners, so there are multiple reason you'll get the dreaded "Nothing To Scan" message.
hiegtx
Dallas, TX
Looking at his screenshot, and looking only at the Fairgrounds system, the OP appears to have appended both the Department (talkgroups) and the site (Fairgrounds). What shows in his shot is the department and site as they appear in the database. (What's shown does not confirm that all the site frequencies are there, but the Site (from the database) does show.)
Since most of those talkgroups are tagged as Business, (one is Security), service type would be a logical culprit. Only Public Safety Dispatch service types (plus the generic "Custom 1") are enabled by default when the scanner is shipped, and when Sentinel is first installed. Those are Fire Dispatch, Law Dispatch, EMS Dispatch, & Multi Dispatch. For public safety, you should also enable the related Tac & Talk service types (Fire Tac, Law Talk, etc).
The Casino in his screenshot would also likely use a "Business" service type.
In the screenshot, some of the names do appear to match the sites as listed in Sentinel, though we can't verify that with the initial screenshot.
For the Des Moines entry (n the screenshot:
There are three listed TGIDs in Sentinel. All are flagged Interop. That's another service type that is not enabled by default.
However, I don't think service types alone are the entire problem.
For the "Polk County" department under the "SARA Network" header, at least some of the listed talkgroups are public safety dispatch service types (Law Dispatch, Fire Dispatch, and EMS Dispatch to be more specific). Those types should have been enabled by default.
#2. I've been at this a long time and I still forget to check download and monitor
I'd agree that this should be verified. In the profile, in Sentinel, is where you specify which Favorites lists should be downloaded to the scanner, and also whether or not that list should be monitored by default.
I also agree with this. Export the list and let someone take a peak at what might have been overlooked. If you are unsure exactly how to do this, see this Wiki article.
phask
zanesville
THIS - a screenshot often shows nothing, or is so tiny one has to expend too much time to even view it.
