- Joined
- Nov 28, 2014
- Messages
- 10
My boyfriend has given me the Model 650 scanner just now for my early Christmas gift! I am sitting here trying to figure out why it says up to send and Clone.. I did install software.. what next? <s>
Just looking for the skywarn frequency...
I now realize that this model doesn't have a battery, just in case of an outage.. No way this can be added to It, correct?
Newbee here...
Just looking for the skywarn frequency which the model 650 tells me goes onto channel 200. While I'm at it.. I now realize that this model doesn't have a battery, just in case of an outage.. No way this can be added to It, correct?
What higher frequency numbers?Thank you very much for all of the wonderful information. My new problem is that I've found out that this scanner does not take the higher frequency numbers, it actually gives me an error, so I will be returning it for a better one. But will I be able to get a refund for whatever I've signed up for here? The scanner software from radioreference.com, wound up costing me 50 bucks.. or will I be able to use the same for the new scanner? I am not sure yet which one I will be buying, all tips will help.
IE: 400.00000
451.83750 for instance is the hospital, plus it doesn't reach as far as I like and would rather have one with a built in battery. Even though I know that someone said I could use a puter back-up, which I don't have. I am aware that I may need an antenna anyway, but would like one that goes further to start with. At least about a 1/2 hour away from where I am. This one is only local.
Allentown PA
No matter what, why would it be giving me errors when I try to put higher numbers in?
I had wanted a digital scanner, with it's own built in battery. I had a Uniden years ago, it was wonderful except it kept losing info because the battery compartment was shot. I don't need a radio with FM. Just a decent scanner. Thank you
What about for a desktop?
I find the BC355N, is the BC15X supposed to be BCT15X? I was just wondering if there was a typo or if I am looking at the wrong one. Thank you soooo much!
