A couple of things to keep in mind when trying to program all of these systems:
-You can only program 1 system per bank
-EDACS systems (Lincoln's system) require you to program using logical channel numbering starting with the first channel in a bank.
-For Motorola UHF systems (Offutt’s system) you will need to program the frequency spacing and offset.
The first couple of times, these types of trunked systems can be tricky. These systems are much easier to program if you are using the Uniden software. If you are still having problems, post with a specific question or send me a PM. If you want, you can send me your programming file from the Uniden software and I will look it over and help you make the appropriate changes.
Let us know if you are still having problems.
--Joe
