New users _ Need a lot of help Uniden BCD325P2
smullen73
Fredericktown, Mo
OK I need help getting this thing going... I thought I knew what I was doing, but turns out I don't...
I had an older Analog BC 125 AT I think.. With the Uniden Software, I had it Programmed to scan my City and 3 others that I frequently visit in under a half hour...
This one, not so much.. I can't even get my Laptop to communicate with the scanner...
Here are my details
Uniden BCD325P2 Scanner
USB cable that came with it
ARC-XT Pro Software
HP Laptop with Windows 7
Connected the scanner via the USB cable to a free USB port, Laptop detected the Scanner, Its Not in Charging mode (Scanner that is)
I think in installed the new Uniden Driver correctly.
In Device Mangler it shows as Uniden Serial Port (COM5)
When I go into the ARC software and try to talk to it, via Read or Send Buttons, I get an Error.
Serial port Not available or in use by other software...
Not sure what to try next...
Please help.
KR3LC
Pasadena, Maryland
I'm not familiar with that radio or that software. Anyway if Device Manger is showing a com port I think you got the driver installed Ok. Make sure in the software you are trying to connect to Com5. When connected to the computer, if the radio lets you select Mass Storage or Serial, you might need to select Mass Storage. That's how other Unidens work.Good luck.
Voyager
Maybe try FreeScan (2.18 or later) just as a test to see if it will talk. If it can, you know the driver/cable/scanner are working correctly.
smullen73
Fredericktown, Mo
Thanks that got me Communicating with the Scanner!!!!
smullen73
Fredericktown, Mo
I was going to try that, but KR3LC's tips got it working... Or at least Communicating...
I'm sure I'll have may more questions after I get some more time to mess with it...
smullen73
Fredericktown, Mo
OK, Next issue....
With the scanner (BCD325P2) using the ARC-XT software, I can attach to the RR database and pull down the info for many agencies in and around the areas I want to monitor. I was able to get it pushed into the scanner...
Now, when I set it to scan, I see it checking the various agencies or Groups yet all I can pick up is radio traffic from a Highschool (in the 151.x to 155.x ranges) less than a mile from my house...
I'm sure I'm doing something wrong, just not sure what...
hiegtx
Dallas, TX
OK, Next issue....
I would suggest that you save your programming file, then attach it to your next post. While I don't use ARC-XT (I use FreeSCAN for my 325P2 & a number of other scanners), other members do. That way, someone can take a peek at your file, and see what might be wrong. Often, it's a simple error or omission, easily spotted and corrected by a 'different pair of eyes'.
To attach your file, you will need to either zip (compress) it first, or simply rename it. Only certain file types can be attached to a post. The easiest way would be to add *.txt (without the *) to the end of your file name. Someone then can remove that extension (the.txt) and open it in the software & take a look.
smullen73
Fredericktown, Mo
Thanks for the suggestion...
I will try and get that done this weekend... I have to work all night tonight, not sure I'll be able to get to it...
Thanks again!!!
Scott
Voyager
Check to make sure both the Sites and TGs are present for any trunked systems.
Also make sure any Quick Keys you assigned are enabled, and that nothing is locked out.
You may simply be out of range of those systems you cannot hear.
Likewise, I don't have ARC, and use FreeScan, but +1 on what heigtx said about attaching the file.
smullen73
Fredericktown, Mo
i guess when I do this I'll have to save all the systems files as well as a Profile file???
Looking at the file structure, it looks like there is a ""Profile file" that has links, ties or calls to each system file, which may have several ""Groups" in it...
So I'd zip my 1 profile file and 2 system files into on zip package and upload that????
Sorry, I'm sure I'm making it more complicated than need be...
