W4UVV
Virginia is installing a VHF Motorola Type II, 9600 baud, P25 in the clear with encryption capability called STARS. 2 ghz. and 6 ghz. microwave links with T1 landlines, etc. will eventually cover the state. This installation per Motorola is the first of its type in the nation. The main user will be the state police. However, other entities to include F&G, Marine Resources, and Forestry also will be users in this "seamless" system. Testing began in October, 2005 and the Richmond, Virginia,VSP Division 1 is the first entity to test and accept the system. The main system test is scheduled for February.
Various 158 and 159 mhz. repeater output frequencies were licensed with various 154 and 155 mhz. frequencies licensed as inputs to Virginia. However, actual off air monitoring has disclosed a few other 158 and 159 mhz. frequencies being used not licensed for that specific geographical area. Confusing the situation more is selected 151 and 152 mhz. repeater output frequencies recently have appeared that seem to mirror image 158-159 mhz. repeater outputs. These 151 & 152 mhz. with only a few exceptions of previous liciensing to F&G are not licensed to Va. but are being used in the STARS system. We cannot determine a reason for the presence of 151 & 152 mhz. "mirrored" repeater outputs to the 158-159 mhz. repeater outputs. One theory is a backup repeater for a possible mobile shadow area. Since they mostly are unlicensed frequencies we cannot do a latitude and longitude search.
Some of us monitoring the STARS testing have experienced much frustration in attempting to locate a control channel. Those transmissions that appear to be data channels don't appear to function as the control channels we are familar with in the 400 and 800 mhz. range. For the past 4 months many various base frequencies and offset settings have been tried in programming with no successful results so far.
The STARS P25 repeater transmissions seem to be stand alone repeaters and are easily copied on a digital receiver scanning in the conventional mode. However, since no control channel can be found so far, scanning the trunked mode produces zero results because of no control channel. Scanning in the conventional mode stops on whatever repeater activates in the scan cycle and there is no continuity tracking of the active communication relationship. There are several 152 mhz. that are 24/7 data channels but it is unknown whether or not they are STARS related. They constantly display "FM/LNK/DAT" but never "P25" when a STARS 151, 152, 158 or 159 mhz. repeater activates.
If it all sounds confusing and frustrating, it definitely has been and still is.
Having read past posts on this website about ALMR, it appears STARS possibly is related to some extent. Those of us monitoring are using Pro 96, 2096, 296D and 796D digital receivers. Previous posts here in this forum are conflicting regarding whether or not the BC796D works on ALMR. Reply Information as to what digital scanners work and those that don't would be helpful.
Thanks in advance for any replies from monitoring experience of ALMR that would assist us in programing the Va. STARS vhf TRS.
