New Windows 11 PC - DSDD+ FastLane - P25 Not Decoding
AB9NN
Beulah, MI
I just bought a new Windows 11 PC and had my data transferred to it. I had been running a batch file on my old Windows 10 PC for years that worked well to decode P25. Now when I run it I get no errors but get only two windows - not the normal third one with the frequencies being highlighted. I don't see any error messages and am not sure what to fix. The FMP24 windows shows the normally strong P25 control frequency with the radio tuned to it and stable. Here is my batch file and output from the FMP24 window: Also, I run Norton anti-virus software. My version of DSD+ FastLane is the one just prior to the most current update. I wanted to get this fixed before I upg
My batch file used to start:
START FMP24 -i3 -o20001 -P0.0 -f853.9625 -_2 -g47
REM Traverse City - START FMP24 -i3 -o20001 -P0.0 -f853.7750 -_2 -g47
START DSDPlus -r1 -e -T -E -Pwav -i20001 -O NUL -_11
Output From FMP24 Screen:
FMP24 2.75
Current working directory is "C:\_Files\SDR - Software Defined Radio\sdrsharp-x86\dsd+FASTLANE-P25"
SDR sampling rate = 2.400 MHz
Spectrum window width: 1024
FFT size: 16,384
Spectrum update rate: 20 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 20.000 25.000
DSD+ path is "C:\_Files\SDR - Software Defined Radio\sdrsharp-x86\dsd+FASTLANE-P25"
Primary frequency list: '.\FMP-FreqList.csv'
Secondary frequency list: '.\FMP-FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 44.6310 -86.0725
Using RTL SDR device #3
Using DSD+ link ID 20001
PPM correction set to 0.0
Initial frequency set to 853.962500 MHz
Minimizing spectrum display window at startup
RF gain: 47.0 dB
Optimizing FFT calculations... done.
Audio output device #1 = 'DELL S2421NX (Intel(R) Display '
SDR device count = 4
SDR device #1 serial string = '00000001'
SDR device #2 serial string = '00000001'
SDR device #3 serial string = '00000001'
SDR device #4 serial string = '00000001'
Found Rafael Micro R820T tuner
Tuner type=5 (R820T)
Serial string = '00000001'
Sampling rate set to 2.400000 MHz
Frequency correction factor = 0.0 PPM
Waiting for DSD+ link with link ID 20001
Loading frequency data...
I/Q data loss detected; auto-enabling extra CPU loading
wgbecks
NE Wisconsin
John,
I just rebuilt one of my PC's with a clean install of Windows 11 using a backup of my original C:\DSDPlus folder for the rebuild without
any difficulties. I would question the bit mapping of -_11 on your START DSDPlus line and would suggest that you remove it and then
be sure to delete the DSDPlus.bin file before restarting your batch file.
This will reset DSDPlus to defaults and whereby you can then set desired options and parameters.
Bill
