What's wrong with the 436?Pro-94 (aka the King of Intermod), followed closely by the 436 I sadly had to get due to ProVoice.
The first gen of the 436HP were lacking in the UHF area. The one that have been built the last couple of years have had that problem fixed. No need for foil over the batteries to help reception is needed. My 436HP is my go to radio now at home. Fire is on VHF, EMS UHF the next county over is P25 simulcast but there is only a single site so it works good no simulcast issues then.Pro-94 (aka the King of Intermod), followed closely by the 436 I sadly had to get due to ProVoice.
r/woosh.Not really a scanner per se. But for the price, I think it does ok.
Simulcast is a weird duck. I'm playing with my BCD325P2 which was awful on a Simulcast system here. I found that on my back patio I can lay it on its back on the fire pit and point it North and it works flawlessly. Stand it straight up and get the robot voice and chop.I don't know that I can specifically name a particular "worst" scanner ever, but I kind of chuckle at the TRX-x and the Pro-197 mentions.
I have a TRX-2 at home that works just fine on the MPSCS system, smack dab in the middle of a simulcast tower county, it doesn't miss a single transmission. I have 3 WS-1080 (a-la GRE PSR-800's) in use between Macomb county and Washtenaw county, both simulcast counties. Work great. I have 2 Pro-197's in service, one works fantastic, one does not.
The difference for the 197's where one works, one does not? Antennas. I've combed the threads here, followed the insights of many well regarding folks here as SME's and put a ton of energy into the antenna systems that these radios all operate on. I guess I just chuckle when radios get dinged for the dreaded simulcast demon as being the worst ever.
The non-intuitive Unident programming software, the layout of the keypad, the "oops you pressed it and now it does NOTHING you want" knob, the "can't listen to it because it needs charging" scheme, and the general uselessness of it in terms of trying to find new talkgroups or listen to something you want....Want to listen to one single TGID? Find the talkgroup through 3 levels of choices yet? Good luck. Want to hunt for new stuff? Gotta lock out literally everything else first.What's wrong with the 436?
Ever heard of favorites lists?The non-intuitive Unident programming software, the layout of the keypad, the "oops you pressed it and now it does NOTHING you want" knob, the "can't listen to it because it needs charging" scheme, and the general uselessness of it in terms of trying to find new talkgroups or listen to something you want....Want to listen to one single TGID? Find the talkgroup through 3 levels of choices yet? Good luck. Want to hunt for new stuff? Gotta lock out literally everything else first.
I've used this POS almost 15 minutes in the 7 months I've owned it.
I'm not the guy that has a scanner because I want to listen to the local police dispatch, and I don't use the database. If those two aren't applicable, then this radio is not for you.
I believe everyone who had one in my area are all dead now
Maybe I should clarify the scanners are dead 😆
For me it was the AOR DV-10
Cool story. What's a favorite list? Something I can select and hit Scan? Oh wait, there's no such button. Want to listen to one talkgroup? Easy money! Turn the radio on, figure out which system it's on, then select the "department", then hit the chan/hold button and turn the knob until you find it.... Just make sure you don't tap that damn thing first, otherwise you're just fiddling with the volume. Don't stop to think at all during the process, because then you have to start all over. Will it hold? Who knows? Sometimes the "department" starts changing all on its own.Ever heard of favorites lists?
My pick is sadly the TRX-1.The only saving grace is EZscan, but software isn't enough if the radio is also not up to par. For more than five hundred dollars it compares more to the 996P2, and not as a flagship competitor to the SDS100/200.
