richee2000
Communications Professional
I should add: this was with the SDS100 inside the car, with the stock antenna
I suspect you are seeing the Eagle Rock site. This is the only high profile site. The others are much lower.I should add: this was with the SDS100 inside the car, with the stock antenna
No I don't think so... I spent the weekend driving around Livingston and there was zero signal. If West Orange was active, there would have been some signal into Livingston. Besides, The eagle Rock site is pretty weak along the Union county mountainside ridge.... I think this signal is coming out of Newark. we need more field testing....I suspect you are seeing the Eagle Rock site. This is the only high profile site. The others are much lower.
When I compare to NJICS W.Orange signal I see some similarities. The Newark signal however has about 7db better signal here with a bit less fading. Very respectable. No traffic yet.
It's not in sentinel yet because before today there were no talk groups listed. It should be in the Monday update in sentinel, for uniden radiosI'm trying to import this system into my TRX-1. I see it on this page:
When I try to do a Library Import, it's not listed. I'm in Essex County.
I'm not sure what I'm doing wrong. Since it's not a big system, I could manually enter it.
That's not correct in any sense. TG 8 has been listed for nearly four months as "System Techs" prior to yesterday's updates. The Newark P25 system has been in Sentinel going back to at least early November. Oh and he's asking about Whistler here, not Uniden/Sentinel.It's not in sentinel yet because before today there were no talk groups listed.
The system is right here in the software, library version 866. When was the last time you updated the library? Note that the only talkgroup listed is the previously mentioned "System Techs", which has changed. Try updating your library this week for the latest updates, or just enter the new talkgroups manually, or use a wildcard to hear all activity.I'm trying to import this system into my TRX-1. I see it on this page:
I just spent about 45 minutes listening to Newark PD p25 system and all talk groups currently in the clear but they are a we broadcast of the 460 channels. Yes first precinct is 1011The RR DB has been updated to reflect updated TG’s. @richee2000 note Inquiry TG’s are encrypted. On the 460.xxx side they are not. Likely indicative of capability and the future. No indication any two way usage by anyone yet. These are simply linked to the 460.xxx side.
Clearly someone is not superstitious. Note the use of 1013 TG for the 3rd Pct. 🤔
Bad info removed, thanks for the report/correction. Nice to have someone with the skill, experience, and knowledge you possess monitoring this (and other) systems in the region.2001 is not REMCS. Its Newark FIRE 1. 2003 is Newark FIRE 3.
