coreymcl said:
OK I have read the manual and I must be blind as I can not find the answer to this question.
How do I manually punch in a feq? I am trying to enter a feq for monitoring air traffic (135.975)
1. Press the Menu button (bottom side of scanner.)
2. Using the Scroll knob (top of scanner) Select Program System the press E.
3. Using the Scroll knob, select New System then press E.
4. Using the Scroll knob, select System Type (Conventional) then press E.
5. Using the Scroll knob select Edit Name then press E.
6. Tap the decimal button (under the 7 button) until all the letters disappear.
7. You?re now ready to name your system.
8. Using the Scroll knob, turn it until the alphabet you want appears then press then press the Func button (bottom side of scanner) while turning Scroll knob to the right to advance one space. If you make a mistake press the Func button while turning the Scroll knob to the left to make the correction. When you finish naming your system press E.
9. Using the Scroll knob select Edit Group then press E twice.
10. Using the Scroll knob select Edit Name then press E.
11. You?re now ready to name your group (Follow directions from step 8) to name your group.
12. Using the Scroll knob select Edit Channel then press E
13. Input a frequency then press E.
14. Press the Menu button.
15. Using the Scroll knob select New Channel
16. Repeat steps 13 through 15 until all frequencies for that group have been entered.
17. When you finish simply press Scan
