Newbie APX CPS Question
ianthompson28
I have everything programed and working except for the radio ID so that other radios will see who is transmitting.
Dispatch asked to program our APX7000XE and APX6000XE to have certain names ie: "466A" and "375C"
Where is this setting in APX CPS (using R11.00.00)
Thank you!
esfd283
Depends
This depends on who wants to see the names you mentioned. If the dispatcher wants to see those names then they can alias the Radio ID to those names at the dispatch center so it displays on consoles etc, if other radio users need to see that then there has to be call lists established etc. For large agencies this is usually not done due to constantly changing assignments. Or if they simply want you to display that name on the radio then you can go to Radio Wide, User Information, Radio Alias Enable, This will open up a field and you can enter the name into this field. This will display the radio name on the front.
Hope this helps somewhat.
ianthompson28
Thank you for the reply :)
I know our PM1500 and others were programmed to transmit a name for that radio and it displays on the radio head for any radio that can read it (almost anything newer)
I will try the Alias but I believe i tried it and it doesn't work for what i am trying. have to double check.
i am sorry if this is confusing. like i said i am a newbie. :)
Can i post my codeplug?
My department is a PITA. We have tk730's, tk790's, tk2180, APX 6000, APX 7000, PM1500, PM400, HT1000 and a few others....
