Newbie, Convert CB to Base Unit
190vw
I have a working cb unit by Radio Shack, TRC-487. which I used in my truck until vehicle died. I was wondering if I can make a base station at home with this unit and the 9 ft whip antennae that I used with it. Photos attached. Unfortunately, I didn't save the coaxial. Hopefully I'm in the right forum to get the info! Thanks.
slowmover
Fort Worth
Get the antenna base as high as is possible.
You’ll need a power supply (5A; 120V to 12V) to run the radio.
RG58 coax.
More details will apply. You’ve enough to get a start, yes, but it’s best to have a thorough plan and go thru listed steps.
A typical CB base station vertical antenna is 18-22’ tall.
This is likely the best known entry level antenna (not an endorsement, but a start point).
A99
The antenna system is make-or-break in terms of satisfaction with any radio rig.
Deserves first place in future plans & $$.
190vw
RG58 coax.
A99
Thanks, diagram looks like a can do!!
