I live in Sacramento CA and I am looking for a scanner and I have no idea what to get or what would work in my area. Could anyone give a recommendation?
Here's a listing of scanners for reference.Could anyone give a recommendation?
I am ordering the 996P2 with programming installed, should I get the DMR installed too for sacramento county?Here's a listing of scanners for reference.
Uniden Scanners - The RadioReference Wiki
wiki.radioreference.com
It depends whether you want a handheld or base unit.
I like the 996P2 base and 325P2 handheld units.
The SDS series are the best units and handle Simulcast transmissions best. They are also the most expensive models out there.
Good luck!
Yes. Just be advisedthe upgrade's about $15 cheaper if you buy it directly from Unidenshould I get the DMR installed too for sacramento county?
Someone from your area would need to clarify which system that Sacramento (city & county) are using.I live in Sacramento CA and I am looking for a scanner and I have no idea what to get or what would work in my area. Could anyone give a recommendation?
You can do the DMR (or NXDN) upgrade at anytime after you get the scanner. It does not need to be done at the time of purchase.I am ordering the 996P2 with programming installed, should I get the DMR installed too for sacramento county?
Also be advised that learning how to program it can be important because what is out there changes.
If you find that simulcast is an issue (and it probably is) then the SDS100 or SDS200 is the best and only radios designed to receive simulcast. They are also easier to program if you have a PC, because you get updates weekly using the radios software and do the programming easily in the computer. Paying for programming is unwise since you need to do it yourself anyway.
Thank you all! I have some decisions to make. My scanner still has Crystal's in it.
did you program it yourself ?Bought the sds 100. Love it so far. Thanks everyone!
