newbie getting back into scanning.with a couple ??
cswrench
Hello, I have literlly dug my pro-29 out of a box and started toying with it again. First off with all the new trunking systems out is my pro-29 obsolete? Or is a trunking scanner more of a luxury?
Lastly. I have moved to Brownsburg In hendricks county. I can not find any Brownsburg PD on any freq lists. Are they on the mecca system with indy?
Thanks for all the input!
jbstahr
West Columbia, SC
I'm not in Indiana, but from what I can see they are implementing a statewide system similar to what Ohio is doing with their "MARCS" System. If you're lucky thats a fairly rural area and not on the system yet. However, I did find a small listing for Hendricks Co:
Hendricks County Talkgroups
DEC HEX Mode Description
7216 1c3 D Fire Dispatch
7248 1c5 D Danville - Fire (?)
7264 1c6 D Danville Fire -
7280 1c7 D Danville Fire - (?)
7296 1c8 D Danville Police - Tactical
7312 1c9 D Danville Police - Dispatch
It's a safe bet that they will end up on the system eventually, so I'd start saving for a Trunk-Tracker. They are great and are becoming more and more of a necessity. Hope this helps, and I'm sure some people from Indy will weigh in with more info.
scannerfreak
Moderator
Indiana
Hendricks County has received $668,501 in grant money to join SAFE-T. It is unknown at this time if and when this will happen. A group was formed to look into the radio situation to either join MECA or SAFE-T. They want to maintain independence, that coupled with the grant money, it looks like they will go with SAFE-T.
You can find current frequency info on Hendricks County here
Brownsburg PD/FD are expected to switch to MECA in the fall.
Your Pro-29 is obsolete in regards to the trunking. You will need a digital scanner to monitor most of SAFE-T and soon MECA as they are upgrading to digital as well in early 2005. You will need one of the following scanners:
Uniden:
BC-296D(handheld)- around $500
BC-796D(base)- around $500
Radio Shack:
Pro-96(handheld) on sale now for $429.99 with the $75 off coupon, the sale ends on 7/18 though so you better hurry.
If I were you I would take advantage of the offer going on right now for the Radio Shack pro-96, You will not find a better price. Consensus is the pro-96 is the better of the scanners for digital trunking and in my opinion it can't be topped.
