Billy_Bottle
- Joined
- Nov 19, 2019
- Messages
- 4
Hi folks. Very frustrated SWL trying to get Sorcerer running on windows 10. I had it going 3 days ago, for the first time, and the next day it won't start up correctly, or at all. Nothing changed on the PC, and I have downloaded from several sources and re installed until I'm done for. What happens is I try to run the exe as an admin, and get no main screen, just a notification in the task bar that would happen anyway had it opened correctly. Sometimes I see an error msg about unable to connect to 'something or other' soundcard, can't remember which one, but it tells me to go into what I assume is a config menu and change it. At least it did- it's not doing this tonite. I know it's not supported now, but loads of users are getting good reliable use from it. Any ideas out there what I can try? I am using an Icom PCR1500, and it makes no difference if the radio is on or off- the only time it did work, the radio was on and I was watching the spectrum on a voice signal on USB, and it seemed to be the signal it was seeing was modulated in response to audio input. All help warmly welcomed! Cheers.
