Newbie Help with G5
WF8MAF
St.Louis County, MO
ok so after waiting during the backorder I decided to save a few days and program my G5 myself. I have the program file with the control freqs and all the talkgroups I want to monitor and I have my knob set up all under one zone. I am in St. Louis so I have knob 1 just using the old VHF they use to tone out the houses and trucks with the tones of my truck. knob 2 is the same just vibrate. Knob three I wanted to scan between the North Dispatch / North Main /Tac talk groups Knob will be be the same 3 just using South talk groups.
Now that I have it all programmed, the pager seems to be scanning ALL talkgroups and not just the ones I programmed and it also has no audio the little speaker is muted unless I hold the reset button. any ideas?
Webodisk
Silent key.
Virginia Beach,VA
Make sure in the zone and channel setting under alert mode it is set to tone
Sent from my iPhone using Tapatalk Pro
gcopter1
Winter Park, Florida
In PPS, go back and make sure you only added the talk groups you need per knob position.
Also, View/Edit Existing Profile>Zone and Channel Setting, double click it and check under the Knob Setting Section>Push to Listen is set to "No".
David_Oney
Former Unication Tech Support
Raceland, KY
Also make sure that you don't have the receiving mode set to trunking TG monitor and are using Trunking TG Scan.
WF8MAF
St.Louis County, MO
Already caught that mistake lol! its working like a charm right now, I just have to wait to get back in VHF range and wait for my house tones to drop to see if I have alert part right
AK9R
Staff member
Super Moderator
Central Indiana
Problem solved. Thread closed.
