Newbie help
kris665
Do you guys see anything wrong with this set up? It was the only place on the car I can think of putting it. Also is it worth it to peak and tune a cobra 19?
LoyalServant
SC
I take it you could not put it on the trunk for some reason?
I can't tell if the car is a wagon.....
Otherwise a magnet mount on the roof would probably be better but if this is what you got, and the SWR is okay ( <=2) then it should work.
kris665
Ya its a wagon the swr is 1.3. It seems like it it preforms better then my Lil wil mag mount. Just didn't know of I should do a base coil that low.
ChetsJug
With out knowing what make car you have, most modern hatch back and station wagon lift doors do not have rain gutters like 1980 and before. They make "hatch back" mounts that will clear the roof when you lift the back door up. I found some really strong ones that put the trunk mounts to shame on ebay. Maybe one can help.
Hatchback Antenna Mount | eBay
And yeah, I'm not a Wilson fan. The only Mag Mount I use is Hustler because it has a shock spring. The Lil Wil solder joint comes loose after a couple years and no amount of repair will last long.
