Newbie in need of help
farmer27
Coppell, Texas
I've tried searching the forums but I'm still struggling any help would be very appriciated.
I recently was given a Bearcat Sportcat SC150, and I have no idea how to get it to work. Reading thru the instuction manuel I have figured out how to scan but I have yet to hear anything but static. I tried going thru all the bands, as well as looking up specific frequencies here in my area (Coppell, TX) but still I get nothing. Any thoughts or suggestions.
And yes I have checked the batteries, volume and power.
Thanks again.
DaveIN
Founders Curmudgen
West Michigan
How about the squelch control, is that working? You should be able to tune to a NOAA weather station when pressing the WX button and hear a continuous broadcast if you have a nearby station.
farmer27
Coppell, Texas
I can ajust the squelch control, if I take it all the way one direction or the other it will stop scanning. Does that mean its working. I can't hear anything on the WX weather channels. When I press that button the LCD just scrolls the word "scan"
farmer27
Coppell, Texas
I went to DFW airport this afternoon just to see if my area was causing me to not pick up anything. I stil got nothing there. I tried scanning the frequencies indicated for airplains and such. Either I got a POS or i'm just doing this wrong.
captclint
Mountaintop, PA
I went to DFW airport this afternoon just to see if my area was causing me to not pick up anything. I still got nothing there. I tried scanning the frequencies indicated for airplanes and such. Either I got a POS or i'm just doing this wrong.
Were you using the Preprogrammed Service Search for air craft? That should eventually pick up aircraft in the air, and airport ops, if you are within 5 miles.
However, what you really need to do is to click on the DATABASE tab above, then on TX, and then on Dallas and Denton Counties to see what is available to program. There are lots of conventional frequencies, and your manual should tell you how to enter a conventional frequency. To start, you may want to put Dallas in one bank, and Denton in another.
farmer27
Coppell, Texas
There is a good chance i'm just an idiot but I am still having no luck at all. I tried several of the frequencies from the databases above never picked up anything.
When I was at the airport I did use the preprogramed frequencies for aircraft. I was parked less than 200 yards from one of the towers and 50 yards from the runway, still got nothing.
Does the bank i'm in make a difference in searching, there is an option between direct and bank?
hiegtx
Dallas, TX
If you were out at Founders Plaza, and did not pick up anything either using the preprogrammed aircraft search, or by trying the airport frequencies here by entering them directly, then I'd suspect a problem with the scanner. You should have heard quite a bit of traffic out there, whether out at the plaza, or, from your description, in one of the other parking lots. The bank you use should make no difference, unless the unit is defective.
Try turning the squelch knob all the way to the end stop. At one end or the other (not familiar enough with that model to tell you whether full clockwise or counter-clockwise is squelch off), you should hear static sound. From the static sound, turn the knob just enough that it quits. If you never get any sound, the unit is probably defective (I am assuming fresh batteries, right?). [Also try this with an earphone or headset, just in case the speaker in the scanner is the issue, but the receiver still works. Long shot, but costs nothing to try.]
Besides a defective scanner, the antenna could be bad, but that close to the runways, you probably could hear something with no antenna at all. You should still get a little static noise, even with no antenna.
While you could send the unit in for repair (if defective), the standard repair rate of about $60, plus shipping, would be close to the cost for a new similar, later model scanner. If you also want to be able to monitor Coppell PD/FD, or most of the other neighboring cities (Lewisville, Grapevine, Carrollton, among others), you'd need a trunk-tracking scanner.
UPMan
In Memoriam
Arlington, TX
The quickest frequency to enter in the DFW area to check for general reception is 162.55 MHz. This is the continuous NOAA weather transmission. If that isn't coming in, then something is broken...
w8jjr
Lincoln MI
It does have a antenna on it right. Try the weather service and remove antenna and place a extended paperclip in it to test if its a bad antenna. Should be able to hear weather.
