I'm a newbie who's fascinated by radio. I've had a couple of scanners, shortwave receivers and even a Baofeng.
I have a few questions and would really appreciate the forums' guidance.
I would like to build an SDR rig that can do it all - function as a shortwave receiver, receive utilities radio, general scanner, Phase II, trunking, DRM, etc. Ideally for as little as possible.
I have a Surface Pro tablet with an i5 and 8 gigs of ram that I think should be suitable for this. This would limit me to Windows, however. I can probably find another laptop that I could dedicate to this if linux is better, but if possible I would like to stick to Windows solutions.
I'm looking at this bundle: https://www.amazon.com/NooElec-NESDR-Smart-HF-Bundle/dp/B0747PX3NZ/ which seems like it can do a lot of what I want.
From my understanding, listening to SW will require use of the Smart HF converter, but without it I can receive pretty much everything above that, correct? It just requires separate antennas, which are included with the bundle, or I'd build my own.
- Is this device compatible with most software?
- What software is considered the most "complete" for SDR in terms of display, receiving, decoding, etc?
- Do I need dual receivers for following trunking systems?
- How do you decode PII, DRM, etc - are these like plugins that you activate within the software, or does this require additional software that you feed the audio into?
- Are there better solutions than the bundle above?
Any additional thoughts would be greatly appreciated.
Thank you very much for your time!
