Newbie Problem TRX-2
nasinclair
Hi All,
Presumedly I'm missing something obvious. Out of box TRX-2 seems to be stuck in 'phones' mode even though nothing is plugged into the headphone socket. So no sound unless I record and playback on the PC?
And if I plug headphones in also no sound.
Can anyone help a guy in need? Thanks
Ubbe
Stockholm, Sweden
If it's out of the box then it's probably using an outdated firmware?
Update EZScan and firmware and DSP and try again.
/Ubbe
CycleSycho
Central South Carolina
:) Suggest you do what Ubbe suggested ASAP, if your still having this issue return it for a replacement. IMHO a warranty call would be after you get something working out of the box, not dealing with an issue from breaking a seal on the box. I would think part of an initial startup would be to make sure all software and firmware is up-to-date, but these newest scanners are a challenge (sometimes). :)
