Newbie Quest.: Freq. Ranges To Monitor ?
BOBRR
Boston, MA
Hello:
New at this.
What is the "official" range for the normal, non-mil, aircraft monitoring frequencies ?
Is it 118 to 137 MHz, or does it start at 108 ?
The same question, please for Military Air Monitoring ?
Thanks,
Bob
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In addition, many National Guard and Air National Guard groups use freqs in the 138-144 mhz range For the most part - the Blue Angels are an exception to the rule here - transmissions are in AM.
If you tune in the 380-390 Mhz area and hear what sounds like trunking data, you're quite right; many fed and mil bases are setting up trunk systems in this range. The 396 and 996 are the only current scanners that can trunk in this band.
73s Mike
