I always program a Favorites list, but it takes a lot of effort. I suspect you used the zip code feature. As stated, make sure the service types are on that match to what you're trying to monitor. I guess you're using the stock antenna. ? Are you near something that might interfere (computer, cell tower, other device that emits RF)? What do you receive? When you are receiving NOAA Weather channel, what kind of signal level do you see? It could help determine if something is blocking your signal path (although they'd likely be different between NOAA and Long Beach).
