Please read one of these:
Trunking Basics - The RadioReference Wiki
https://en.wikipedia.org/wiki/Trunked_radio_system
https://www.taitradioacademy.com/topic/how-does-trunking-work-1/#:~:text=When a trunked radio user,so at the same time.
P25 II is
digital.
I don't specifically know why analog is working (radio seeing digital and ignoring the setting)?
Now with the hex:
The "1E7" is just the system ID.
It does not need to be programmed.
The only thing you have to pay attention to (and program) are the
sites themselves, each with it's
name,
control channel and it's
alternate(s). Also your
(DEC) trunk group numbers and each
trunk group name.
In RR:
South Sound 911 Trunking System, Lakewood, Washington - Scanner Frequencies
Red = control (see the little
c behind the number?)
Blue are the alternates. (see the little
a behind the number)
RFSS | Site | Name | County | Freqs | | | | | | |
1 (1) | 001 (1) | Tacoma Simulcast | Pierce | 773.43125 | 773.68125 | 773.93125a | 774.18125 | 774.43125a | 774.68125c | |
1 (1) | 002 (2) | Orting Simulcast | Pierce | 769.33125 | 769.58125 | 769.85625 | 770.10625 | 770.35625a | 770.60625a | 770.85625 |
| | | | 771.78125 | 773.45625 | 773.98125a | 774.48125c | 774.73125 | | |
1 (1) | 003 (3) | South Simulcast | Pierce | 771.13125 | 771.55625 | 772.05625 | 772.68125 | 773.23125 | 773.73125c | |
1 (1) | 004 (4) | West Seattle | King | 769.30625 | 769.80625 | 770.30625 | 770.80625 | 773.20625a | 773.70625 | 774.20625a |
| | | | 774.70625c | | | | | | |
1 (1) | 005 (5) | Buckley | Pierce | 771.38125 | 771.95625 | 772.43125 | 772.93125a | 773.48125c | | |
One Note:
SS911 does have some encryption:
(You can't listen to it)
40108 | 9cac | DE | PCSO Tac 1 | Pierce Tac 1 | Law Tac |
40113 | 9cb1 | DE | PCSO Tac 2 | Pierce Tac 2 | Law Tac |
So, after reading these replies I'm being referred back to how I originally tried, which I will try again. I've created several different "systems", each using a different method and I'm receiving good communications, I'm just trying to understand this scanner better. I also, want to be able to identify each transmission when it pops up, so it sounds like if I:
1 - create a system
2 - program the control, alternate frequencies (under "sites" on my scanner)
3 - program TGIDs and name them (under "groups" on my scanner)
I should then be good to go.?
Still perplexed in how I was/am receiving transmission with "AGS digital" turned off.
I will say though, that one of my "systems" , all I did was program the control frequencies under one "site" on my scanner and the "Site ID HEX code" 1E7) under "group" and I'm receiving good transmissions on that "system". Problem is with that, is I can't see where each transmission is coming from. I know the area well geographically so if I'm listening close I can pretty much tell, but I want to know whether it's PCS or TPD or ??
Thanks .. I know I'm very green here and like I said I'm my original post, I'm sorry I'm advance lol.
