Newbie request for information
dsk3331
Madison, Ms
As a new ham radio operator in Central Mississippi (Jackson), I trying to navigate my way through the myriad of unknowns in my new Amateur environment. Can someone educate me on whom I should contact to install a Diamond X50A antenna in my attic to support my new dual band radio?
Thanks much!
Don @ N9LVB
robertmac
There is an Amateur Radio Antennas forum under the Amateur Radio Forums. If you don't receive many answers here, you could look under that Forum. Or you could request an administrator to move you post the the Amateur Radio Antennas forum.
FKimble
Newnan, GA
Most hams are a DIY type. Join a local club and with a little luck, you will have a lot of help getting that X50 up and working. I have a X50 in my attic. Great little antenna. You can hang it from the ridge beam with a eye bolt or hook. Just tie it to the main bottom metal part to take the weight and a little velcro or string to tie the upright part to the support cord to keep it verticle. Or bolt it to a cross support via included brackets. Also put another hookor two to install the coax's weight as you route the coax downward. Use a good name brand LMR 400 coax. I suggest mounting the antenna, figuring out the coax routing before ordering the coax. Always order it a little longer than you think you will need. A few extra feed will not hurt your signal strength. A little too short and you will need to add another length of coax. This is not a show stopper, just not as neat looking! An you will probably be the only one to see it. Welcome to the hobby!
Frank
