I have a Unication G4 coming soon, so I started building a program to have it ready when my G4 gets here. I have a question, does anyone know if I can program two different P25 systems on the same profile?
You can have many P25 systems in the same profile. But only one in any particular knob position.
Out of range *knowing that you're in the SITE tower coverage* usually means you need to check the WACN, System ID number and SITE number.
Well that stinks. Maybe you ARE out of range of the SITE towers you're trying to get. These things have great range with a Yagi antenna too. I am able to get the counties north and south of me using one of those. Nothing with the WS1080.
Verify that the control ch listed is correct. I received an out of range message on a system where RR had an incorrect CC listed. Also be sure you are entering the hexadecimal number (number in parentheses) for the rfss and site. If none of that works, I would try substituting the wildcard FFFF.
I found my problem. It was site data that I listed incorrectly. Thanks for the help.
I see this working pretty well also but it varies... on at least two different statewide systems, I've seen the radio "hold onto" a CC frequency for a site footprint that I left for extended periods. I've learned to both use the stock antenna while traveling and to do more custom programming where I control the site being monitored by programming each site into a different knob position. This is actually a carryover from my experiences with scanners where I wanted the control of which site or sites to monitor vs. letting the radio decide for me. The one downside of the Unications (which are not scanners so it's "ok") is that you can only monitor one site at any given time.That's good. You're going to like using these radios. I took a trip through 5 counties and 6 different SITES from the same statewide SYSTEM and never lost the signal once. And that was with the pager/radio sitting in the drink holder, no outside antenna needed. Only once did the radio try to hang on to the old Control channel of the county I was leaving. Simply turning the knob and then back let it scan and it found the new CChannel for the county I was entering. I look forward to all the firmware updates that they can dream up. ;0)
Yes. The pager just has one profile in it.
You can have multiple systems within that profile.
You can have multiple systems within a zone.
You can only have ONE system per KNOB position.
So Zone 1, Knob 1 could be system A, Z1K2, System 2, Z1K3, System 1 with different talkgroups, etc.
Zone 2, Knob 1, System C.
There are 8 knob positions per zone.
Very informative. I have been thinking about get a U4. Been hesitant to wait for when Phase II is available.
How many zones can you have? I understand that it is 8 knob positions per zone.
I see that it records audio but only 32 minutes worth? Is that 32 minutes worth per zone or total? When you want to move the files to computer, do you transfer the files easily to computer?
The G4 does a great job on Phase 1 simulcast systems in your area - Baltimore City, Baltimore County, CMARC, etc. Of course, it remains to be seen how well the Phase 2 capability (hopefully soon?) will work.
