Newbie with RD5R. Substantially lost.
K7LSV
I have a new rd5r and am in my second day figuring it out.
I have created a codeplug based on a simple example.
I am not close enough to go directly to a repeater so I got a hotspot (MMDVM) and I have it set up.
I am stuck trying to determine if I am transmitting. Basically I don't know what the procedure is to make a call.
Any help would be greatly appreciated.
Morris, K7LSV
usswood
Terre Haute, IN
you must have Talk groups loaded in the programming also...this is what you select to talk on...best advice is to download an already proven code plug for your area...it will have the talk groups all ready set in the programming... then select a talk group and transmit... if you want a signal report, try Tac 310 (310) or Indiana state wide (3118) someone is always on those groups ... even Nationwide (91) is pretty busy most of the time
K7LSV
Thanks for your response. Having talk groups messed up was part of my problems. I could not get to that and the other things until I figured out that the radio and the hotspot had to have the same correct ID. That helped a great deal. Got that figured out this morning after a helpful dream last night then things fell into place.
Thanks and 73's,
Morris K7LSV
INDY72
Indianapolis, IN
It took me a couple tries to get my codeplug set up in what looks like a workable format. I know it works fine for monitoring and will test it for broadcast when I retake my tech test most likely in March when scheduling allows. I have mine set up for the Indy Metro area and can send a copy of my codeplug after Monday when my internet is set up on my laptop.
