newest firmware release?
JRush311
Monroe, N.C.
just wondering if anyone knew when the newest fimrware coming down the pipes was set for?
particularly interested in the encryption mute option
RRR
OFFLINE
USA
Is this the one that will enable DMR finally?
mitbr
Tampa Bay Florida
I do not know..I do not work for Unication we will have to wait and see what features the update will have!
Tim:cool:
CanesFan95
Was Homeboys-Scanna
Banned
FL
So how did you know there's a beta in testing and the ETA?
ThePhotoGuy
Maryland
What radio ID issues?
I have noticed it on at least 3 Phase I systems. I only monitor one Phase II and I haven't noticed the issues. Radio Id's are 7 numbers long around here and sometimes you will see 4 or so numbers when they should be 7.
Unication is aware of the issue.
IAmSixNine
Dallas, TX
Interesting, and your not confusing the TG with Radio ID.
If i have my device in monitor mode it will display TGID over the RID. Otherwise i have not seen the issue you are referring to.
One system i monitor is Phase 1 and several of the units get chatty and i have not noticed any RID issues with it.
I would suggest running trunker to see if it supports my theory. Im watching it now on a local system and most users are 7 digits long starting with a 7 but one RID (dispatch console) is showing 4 digits on trunker. That is also the same RID that the G4 shows. Actually two more 4 digit numbers just appeared and they look to be dispatch consoles for other departments on the system.
ThePhotoGuy
Maryland
No, there are some issues with certain Phase I systems. I run Unitrunker and have my BCD436HP running and it doesn't show the radio id issues that sometimes show up on my G4.
I have talked with Unication Rep's before and they are aware of the issue.
RRR
OFFLINE
USA
I hope it will fix the "Harris patched talkgroup" (65XXX series) to where it will record those transmissions like it does every other transmission...
APX8000
Sarcastic Member
AES-256 secured
Unication is aware of the radio ID issue. I’ve personally reported it. And it’s been seen on every P25 system from Phase I to II and both Motorola and Harris.
IAmSixNine
Dallas, TX
I must be lucky or have systems with out issues.
Ive been watching my G4 units since i read about this and not seen any radio ID anomaly.
KX4KDH
Powells Point, NC
I sure hope this new version will do QCII over P25 conventional. I have an entire county that would buy these if it had the ability.
