nexedge channel spacing
aj4ls
ky
Hello forum members. I have a question, will the nx 740 which is 6.25 khz only receive nexedge digital signals that are 12.5 khz. Thanks in advance for any help.
No. The NX-x40 line of radios will only tx/rx using the "very narrow" 6.25KHz NXDN mode. It will not receive/decode "narrow" 12.5KHz NXDN mode. The data rates for the two versions are different. (4800 vs. 9600)
rg65
However, the new v2 NX-x40 radios will do 12.5 digital and 6.25 digital. But, as he said, the mode has to match or it will not decode.
Sent from my iPad using Tapatalk HD
ramal121
Lots and lots of watts
Calif Whine Country
NX-740/840's with Version 2 won't be released until June 2015. Still a few days to go.....
Version 1 radios can't be upgraded to version 2.
We're just now getting portables. Put out some NX-340's V2. Huge firmware bug. TX audio was terrible, low, tinny, and garbled (like you were on the fringe). No amount of knob twisting in the software would make it sound decent. Had to upgrade firmware from v2.00 to v.2.01. All is fine now. If anyone gets first release units, check before passing them out.
Apologies to OP for thread misappropriation.
aj4ls
ky
Thats what i thought. This radio is useless to me. Guess i will try to sell it, Thanks for the help..
aj4ls
ky
Some of the agency's around here that i want to monitor are using both 6.25 and 12.5 khz. I have an NX 700 that works great, but this radio does not suit me so im going to sell it.
SAFFA
World
I also think NX-_40 radio could have a few more features. Biggest gripe I have is that I can't scan between digital channels and analogue radios. This has given me a few headaches as many clients have multiple channels and not all are digital and they want to monitor all there channels.
If you compare other manufactures entry level digital radios they are all cable of this, Motorola, Icom, Hytera etc.
Maybe they have changed this in version 2, not sure.
SAFFA
World
I also think NX-_40 radio could have a few more features. Biggest gripe I have is that I can't scan between digital channels and analogue channels. This has given me a few headaches as many clients have multiple channels and not all are digital and they want to monitor all there channels.
If you compare other manufactures entry level digital radios they are all capable of this, Motorola, Icom, Hytera etc.
Purchasing the lowest tier radio and wanting more features? The NX-x40 is the absolute lowest tier NXDN radio that Kenwood sells. If you want more features you need to step up to the NX-x20, NX-x10, NX-x00 or NX-5x00 models.
SAFFA
World
I agree. Point I'm trying to make is that if you compare the nx-_40 to other manufactures entry level radios you are getting a few less features on the Kenwood.
In our market the Kenwood is also about 40% more expensive than Icom and Motorola.
