NFM or FM
MasterPo
NY
Notice something today on my scanners I had SIPD(482.8875) on myBC125at in NFM mode on the SDS100 I ad same frequency but in FM mode, it sounded a lot better in NFM so I switch the SDS100 to NFM and still works and sounds just s little better, so just what is the difference between the two modes and what mode should it really be in, thanks in advance
Bill
N2YQC
nd5y
Wichita Falls, TX
NFM is 2.5 kHz transmit deviation.
FM is 5 kHz transmit deviation.
The receiver should have matching bandwidth and audio level, but they don't always. It depends on the type and quality of receiver.
For a scanner use whatever works best.
wtp
Port Charlotte FL
{\displaystyle {\begin{aligned}y(t)&=A_{c}\cos \left(2\pi \int _{0}^{t}f(\tau )d\tau \right)\\&=A_{c}\cos \left(2\pi \int _{0}^{t}\left[f_{c}+f_{\Delta }x_{m}(\tau )\right]d\tau \right)\\&=A_{c}\cos \left(2\pi f_{c}t+2\pi f_{\Delta }\int _{0}^{t}x_{m}(\tau )d\tau \right)\\\end{aligned}}}
where {\displaystyle f_{\Delta }=K_{f}A_{m}}
, {\displaystyle K_{f}}
K_{f}
being the sensitivity of the frequency modulator and {\displaystyle A_{m}}
A_{m}
being the amplitude of the modulating signal or baseband signal.
OR
if it sounds better use it.
narrow FM is just that, it is more narrow a signal, to fit more channels in a given band.
kind of like fitting more small cars in a parking lot than station wagons.
if you use FM on a NFM signal it will sound lower in volume
if you use NFM on a FM signal it might get choppy.
most things are now narrow FM.
littona
Super Freq
Council Bluffs, IA
NFM=Narrowband FM. So it's wideband vs narrowband.... so 25kHz spacing versus 12.5kHz. Most stuff these days was narrowbanded via FCC mandate.
