Hey everyone.
I'm wondering how others in the area are hearing the new NFRRSA system? I live in extreme NE Cobb county. With a rubber duck, I get a so-so signal inside my home, but pretty much full scale outside. I have a commercial grade 800 MHz antenna on the roof that lets me hear multiple TRS's around town. When tuning into the new Fulton system, I get an absolutely full scale signal, but no decode. Not sure if it's multi-path &/or multi-site issues? My decoding is choppy at best with a rubber duck outside. Also earlier today I went mobile into Fulton. Took the radio with me. Used an external 800 MHz scanner antenna on the roof. All around good signals, but terrible decode [for the most part].
I also realize this is a Uniden general purpose radio, so I don't expect results like an over priced Motorola radio. But with the default settings, and a good signal, I'm not getting very good decode. Cobb's TRS on the other hand does decode very well. Even moving mobile. So at least the latest firmware from Uniden has done something right.
Other than trying different antennas (multi-site issue) or moving my physical location (multi-path issue), what are you guys doing to get a better decode? I even have my radio set to ID searching (vs ID scanning) and opened the squelch up all the way. No changes noticed. Maybe some other software settings need to be tweaked for better performance? Again, I've got a Uniden 436HP hand held radio.
I know the Fulton analog TRS is old, but at least I could hear everyone on it. Starting to miss it.
Tim, WK4U
Tim, WK4U
