Niagara County public safety monitoring
WNK1
I programmed my apx 8000 radio with the frequencies for Niagara County Public Safety System from the radio reference database, but I am not hearing anything, yet I can hear them with my SDS100 scanner, with no problem. Anyone have any idea as to why I am not hearIng them on my apx8000? Thanks
Forts
Ontario, Canada
So... have you programmed NAS before? I sure hope you know what you are doing or you could have an inhibited radio before you know it.
That being said, it's usually something to do with the scan list setup or the bandplan has been entered incorrectly.
WNK1
Thanks for the reply. It was programmed through my technician and I will have him check your information. I can see all the different talk groups programmed in the display, but can’t hear any of them talking.
wa8pyr
Staff member
Lead Database Admin
Ohio
That's typically a sign that the band plan info is incorrect.
Hmmmmm…. a legitimate tech should have known about that.
WNK1
No. We are taking the information from the Radio Reference database. We are in Canada 🇨🇦
WNK1
I can see the different agency names in the display, such as sheriff dispatch, fire tac1 etc. as I change the channels, but when it’s in scan mode, nobody is talking. Thanks
n3obl
Ø
PA
that means something is wrong with your programming or tekk-nishun!!!
GTR8000
NY/NJ Database Guy
BEE00
OUT OF RANGE means you are trying to access the trunked system directly, which should NOT be happening. Luckily you/your "technician" are even more clueless than previously thought, so the system isn't even programmed correctly enough to receive the control channel. Amazing.
Stop now and stick with the scanner for trunking, period.
WNK1
Thank you very much for the help
I have taken the radio to a different guy, and he has removed the niagara county stuff. He has also checked the rest of the programming and verified that it is good on everything else.
