Niagara Region P25 System
Enjoi19
Ontario, Canada
Hi everyone,
Wondering if there is anyone in Niagara Region who could confirm the P25 system info. I’ve taken my Unication G4 up there twice, including today, and it doesn’t seem to want to lock onto the system. Says “scanning” then times out and goes out of range.
I’m wondering if perhaps the system ID isn’t correct. I unfortunately don’t have my laptop with me to correct it or put in the wildcard. Is the Hex still 6F1? Anyone able to double check it?
Saint
Fort Erie Ontario Canada
Hi everyone,
The Regional system information is correct, it works on my HP436
Enjoi19
Ontario, Canada
The Unication hardware also utilizes the system ID in programming. I’m sure the frequencies are correct, was just wondering if something else had changed. I’ll have to try the wildcards and then try to hit it from the waterfront in Toronto one day. Wish I’d brought my scanner with me as well today.
Forts
Ontario, Canada
I'll be in the Falls tomorrow and will have my G5 (and other radios) with me. I'll let you know how it goes but I'm not expecting any issues. I had some great tropo last week and was able to pull that system in on a commercial radio with no problems.
Enjoi19
Ontario, Canada
Definitely let me know! I just pulled the data with the import feature in PPS, I took a look and it all seems to match. Wondering where I could’ve gone wrong.
I’ve been able to pull it from the lakefront in Toronto before pretty well, so I should be able to test it more on Friday perhaps.
Enjoi19
Ontario, Canada
I got a lock on it now (From Oshawa!!!!) The system ID was correct and comes up as 6F1 when using a wildcard.
I believe the RFSS in the DB may have been my issue - it’s listed as 0 and imports as that, but I’m getting it as 1 when setting it to wildcard in PPS.
ve3ext
I'm in Niagara Region using a TRX-1. It worked fine last time. I'm seeing but not hearing talkgroups.
What am I missing here?
tnx
Jerry
Enjoi19
Ontario, Canada
tnx
Jerry
Last time I took my 436HP there (several months prior to this post), I had a great signal but was continually losing the control channel - So perhaps simulcast reception is your enemy here.
bacdraft303
toronto
Like everyone else I'm having an issue loading Niagara. Everything seems fine on the program however when it gets to the radio all the talk groups are there but everything else seems to disappear.
I've never been one to program scanners and wonder if it's my issue and not the radio. Is there anyone in the Toronto area willing to help with the G5?
Forts
Ontario, Canada
Sent you a PM. If you can’t work it out you could also export the codeplug from the pager and I can take a look at it.
