Nicecast Issue
Nate1n22
Muskegon, Michigan
I am trying to host my live feed, but whenever I try to start the broadcast it says "Error: Login failed, retry in 10s"
I followed the Wiki page exactly and I still get this error.
Deziel0495
What port did you change it to? I receive this error nonstop
The RR Live Audio application normally uses port 80. You can also use ports 8000, 8080, or 8500. The alternate port numbers are typically used to get around firewall problems. You may also need to use port forwarding on your router to allow your feed through.
BigEvil
Los Angeles
I'll mess with port forwarding on my Time Capsule. I tried all four of the ports above but to no avail.....
Does nicecast include tags? I want my listeners to enjoy those.
Thanks much
