All similar batteries not created equal
Even batteries from the same package may not age the same. One concept behind functions on chargers like the Maha C9000 is the ability to "analyze" batteries so you can put those together which demonstrate similar values. I've had some "good" 2000mah batteries that rated as good as, or better than, some of those name brand 2500mah+ batteries.
You'll also find that these ratings change depending on charge & discharge rate. The ratings supplied WITH the batteries when you purchase them only provide a single value. So that 2500mah battery may provide that life in a 50ma flashlight, but does not even come close when used in a radio @ 300ma(+) load.
Without any other way to determine which batteries are matched, I guess you have no other choice but to go by (brand &) capacity ratings. However it appears that a much better way to go is to use these fancy chargers and match them based on testing results.
I'd totally diagree with that conclusion. Brand means NOTHING. I've discovered the worse batteries I have are those with big names on them (DuraCell, Energizer, to name 2).So, basically what you are saying is to make sure all the batteries are the same brand with the rated MAH, or it will cause problems.
