I like the idea of having the first run battery and door and also having the 2nd run battery and door. A plus for us first adopters in my opinion.
Standard packs in test units have been single cell 3.7V 3600 mAH. I'd assume the extended pack is going to be single cell as well just more angry pixies stored.Thanks to all who answered my question about the lithium batteries being Li-Ion or LiPo. I plainly see from the pics that BOTH the first production run (with the smaller capacity battery) and all future runs (with higher capacity batteries) will be LiPo.
Follow-on question... from what I can gather, the first smaller capacity battery is probably a two cell battery? 3.7volts X 2 = 7.4 volts. If the radio needs to see 5. volts, that would suffice. But the usage life of this fully charged battery was only around 3-4 hours. What did Uniden do to increase the usage life of the newer higher capacity battery? Add another cell? Or two cells in parallel?
My limited knowledge of lithium batteries tells me from a users standpoint there is not much difference between Li-Ion and LiPo characteristics EXCEPT the physical aspects of a LiPo allow for “molding” of the individual cells into an enclosure... allowing for stuffing more cells into the same confined space (or in this case an added 8mm of space afforded by the larger battery cover). Li-ion cell’s come in a form factor slightly larger than a AA disposable. I pose this as a question also. Comments are welcome please.
Can you elaborate on "withstand"? As in, more even current draw, or less chemical stress on the battery, or...? Just wondering.Another difference is that LiPO batteries can withstand higher discharge currents versus Li-Ion.
Ok, one disappointment on the final units with final battery. I really don't like battery life (max 320 minutes). So, we'll change to a high-capacity battery (entails a new battery door and making the unit about 8mm thicker at the base...which should actually relieve those of you worried about instability).
But, we aren't going to delay first shipments. Instead, all first adopters with the "standard" battery will get a free extended battery+battery door once they are available, around August. All you'll have to do is register the scanner and we'll automatically send when ready.
Here's the notice we're putting in the box for those first units:
Correct name and address that is also the site where you get DMR NXDN and PROVOICE upgrades
