NIPSCO
Napalm
Lake Co, Ind
I've slowly started updating the Db page for NIPSCO around where I live.
The fcc data isn't correct or NIPSCO is just doing whatever they want. FCC lists 935.150 as their Gary site but I've verified it by standing underneath the transmitter in Crown Point. It's definitely coming from there LOL.
I have Wheatfield and Thayer added to the Db and in the coming days I'll submit frequencies and LCNs for CP.
To save me a trip to Gary is there anyone north of Ridge Rd or even 30 who can take a listen around 935MHz? The Gary transmitter is just off 15th at their giant electricity sub.
David.
Napalm
Lake Co, Ind
This license shows 935.150 at Crown Point. This license shows 935.150 licensed to several of their sites.
Interesting. Like I said, I'll map out Crown Point probably tonight after work and submit it. It's entirely possible that Gary is on 935.150 as well, there's a lot of geography in between. I'll just drive up there later this week.
Napalm
Lake Co, Ind
I also have a NIPSCO node on Calls if anyone wants to remotely monitor it. It's parked on Wheatfield but I hear systemwide calls on it, or at least neighbors as well. Terre Haute and Lafayette have been heard on there.
Napalm
Lake Co, Ind
This is what I have so far. Eventually I'll figure out how to map this out in graphics.
Anyone have any more to fill in? If I have LCNs and freqs that means I can receive it from my location in south lake county.
NIPSCO
935.1500 Site 1 LCN 13 Crown Point Neighbors: 2 25 22 21
37 935.45
44 935.5375
52 935.6375
935.2625 Site 2 LCN 22 Wheatfield Neighbors 7 33 27 21 1
96 936.1875
385 939.8
389 939.850
901 946.25
935.675 Site 3 LCN 52 Neighbor 4 29 25 24
32 935.3875
35 935.425
110 936.3625
935.0375 Site 4 LCN 14
935.3875 Site 7 LCN 32
935.1375 Site 8 LCN 12
935.2875 Site 33 LCN 584
935.2125 Site 21 LCN 18 Thayer Neighbors 1 2 8
106 936.3125
384 939.7875
398 939.9625
2446 965.5625 (unit to unit)
935.6375 Site 22 LCN 52 *
362 939.5125
935.450 Site 24
939.5625 Site 25 LCN 366
935.3000 Site 27 LCN 25
941.2875 Site 29 LCN 509
west-pac
NIPSCO
37 935.45
44 935.5375
52 935.6375
96 936.1875
385 939.8
389 939.850
901 946.25
32 935.3875
35 935.425
110 936.3625
106 936.3125
384 939.7875
398 939.9625
362 939.5125
935.450 Site 24
What is the System ID?
west-pac
It shows Network 10
Please stop making changes to that DB entry.
This is an Apple Vs. Oranges situation.
Somebody mapped out that systems using a different software and format than what you are using.
Now that DB Entry is AFU-UFA, and DB Admins will have to determine if they can undo any errant updates that have been done; or scrap the entire entry and start over.
The original format that was used was: L11 Region(dot)Site number.
The format that you are using is: L10-(site number).
You can't mix them.
Napalm
Lake Co, Ind
You can't mix them.
Then I'll just keep the information to myself and map it out for my own use. Or advise me how to make proper entries for this site.
As it is the database entry is useless for anyone trying to program it.
Napalm
Lake Co, Ind
Right now I'm trying to add traffic channels and the correct control channels to the correct sites.
Most of the sites have the wrong CCs and no traffic channels.
AK9R
Super Moderator
Central Indiana
I see you've been revising the Wiki page for this system. That's good! Maybe use the Wiki to map out the changes and once you're comfortable with the info, ask others to look at it to see if you are on the right track.
wirr
Senior Member
We are trying to clean this system up. Much work has been done so hopefully it is looking better. Please continue to put your research in the Wiki, thanks!
west-pac
Do we know who the original submitter was for this system, years ago?
I would like to know which SDR software they used. Whichever software is was, does not read DMR T3 data the same way that DSD+ does.
The data that each of those pieces of software gather, are not compatibility with each other.
If we knew the original software used, we could use that software to see what, if anything, is missing from this DB entry.
??? vs. DSD+, is like comparing apples vs. oranges. Looking at this system using DSD+ will make it appear to be a big hot mess because the only thing that is the same is the frequency.
wirr
Senior Member
I was the submitter in 2018 that noticed the change from EDACS to DMR. At that time DSD was showing this system mostly as L11 with regions but now DSD shows L10 without regions. I've seen this happen with one or two other systems that I believe are Cap Max; I have no explanation for this other than it would seem to be some kind of Cap Max anomaly.
