NJ Parks Police
buckbull
Have channels 1and 2 programmed Haven't heard anything in a while. Did they move somewhere else and I'm missing it? Thanks
trentbob
Silent Key W3BUX
Bucks County, PA
I don't listen to them anymore because I'm retired now but I believe they moved to NJICS, the state p25 phase ll system, tg... 1541 and 1543...
Check under the DEP. Check the database for the simulcast site nearest to you. Good luck.
Tech792
Central NJ
They're still on NJICS. Talking right now as I type. Check your programming or antenna.
RadioDitch
Field Operations Member
Not Where You Think
They've been on NJICS for quite some time.
They do infrequently utilize the old conventional frequencies direct to speak unit-unit without Trenton listening. You'd need to be in the area though since I'm pretty sure they're on low power from what one of their officers told me last year.
GM
I noticed in the past few days, the NJ Parks Police talkgroups have not been simulcasted on the NJSP 800 TRS at all. So I'm going to say it's safe to assume at this point that the DEP talkgroups on the NJSP 800 side are no longer active. They are still active in Phase 1 mode on the NJICS 700 side at all times currently.
trentbob
Silent Key W3BUX
Bucks County, PA
I had heard that 800 MHz smart zone system was going to be phased out by the end of 2022. This came from a close source to the system which doesn't necessarily mean it couldn't be delayed till later.
lion2479
Is Parks still active in Phase I on NJICS? They were a few weeks ago, but haven't heard a peep recently.
Thanks in advance.
GTR8000
NY/NJ Database Guy
BEE00
Thanks in advance.
TG 1541 has been exclusively TDMA since midday December 30th.
