NJICS
wb2cgb
Fair Lawn, NJ
I am using a Uniden 536 and am only getting two or three transmissions daily from Tenafly or Oakland PD on the NJICS site. Is anyone else having this issue?
Alarmguy
Former Alarm Guy, turned Radio guy
Deep in the heart of Jersey
You need to have the Ramapo site in for Oakland. Oakland operates off Ramapo all the time, as it is their primary site. You could also be dealing with simulcast distortion. I'm near Oakland and monitor it on Ramapo with no issues.
wb2cgb
Fair Lawn, NJ
Ok so if I put the scanner on hold and listen to Oakland TG 4915 I should be able to monitor that frequency like the analog frequencies?
Alarmguy
If you have Ramapo as one of your sites yes. You can check Oakland on 45.9800, they simulcast to lowband.
GTR8000
NY/NJ Database Guy
BEE00
Can anyone tell me how to program the control channels in the NJICS into Uniden 536 using sentinel software?
You don't really need to program anything, it's all already in the Sentinel database. Open the system in Sentinel, then Append it to a favorites list. You can delete the sites you'll never listen to if you want, that will make scanning more efficient.
wb2cgb
Fair Lawn, NJ
I did that and just have the Alpine and Ramapo sites, but it doesn't receive the transmissions consistently.
GTR8000
NY/NJ Database Guy
BEE00
Only one control channel per site will be active at a time, and frankly, the control channels on this system do not change (roll) very often, almost never unless there is an issue at the site, then they revert back to the primary control channel as soon as possible. As long as you have the most up to data Sentinel database and have appended that to a favorites list, there's not much more you need to do for those sites.
When the scanner is scanning those two sites, are you seeing a strong, solid signal? Is the scanner displaying DAT when it's idle on each control channel? What is your squelch set to? Have you modified anything else in the favorite list?
wb2cgb
Fair Lawn, NJ
Yes , the signal is strong when I randomly receive it (Tenafly and Oakland PD) It does display DAT on the control channels and the squelch is set to 3. Nothing else was modified.
