NJSP Control Channel and Intellirepeater Question
So Far Away....
ok,
so i now do most of my data entry into Win500 manually,as im sure many of
you do.the RR DL service is great,but i like to have more choice and control
when setting up my scan lists.
now im doing the NJSP,A-South, im in Philly so its the closest to me.the radio,
Pro106
my question,
im adding the CC's for the system,but using Joe-C's phila area guide its got
a bunch of the info for the Intellirepeaters,,
where should i enter the freq's for these,into the CC table Or just add them as
Conventional and assign the propper scanlist?
robbinsj2
Bridgewater, NJ
You would enter the intellirepeater frequencies as additional control channels for the same system, then set multi-site as needed since they are really separate, very small sites on the same parent system.
But you're probably best off omitting the intellirepeaters altogether unless you are in or routinely travel through an area which isn't serviced by the main site.
Jim
